Author Topic: Gas return cable  (Read 2691 times)
Brunow
Gas return cable
« on: October 11, 2006, 12:44:25 PM »
My gas cable was a little ... old so for safety reasons i went to the honda dealer after a new cable. (+ some other stuff)
The (old man) after the bar asked my if my gas return cable was still ok? Err what is a gas return cable and why do you need it for?
I think... i've seen on the carb's there is a big spring who pull's the gas back.
So you don't push a cable with your handel?
any idea's?
Offline csendker
  • Chris; '75 CB550 & a Crusty 'ol boat
Re: Gas return cable
« Reply #1 on: October 11, 2006, 01:04:06 PM »
If you mean the throttle cable(s), most of these bikes used a 'push'-'pull' dual cable system.  The big spring on the carbs was used to automatically return the throttle to the idle position, which the "pull" cable works against this spring to open the throttle.  The "push" cable was a safety measure in case the spring breaks, you can still force the throttle closed manually.
If you want to replace one, you probably will want to replace the other too.  Just like I'm looking to do...  ;)
Actually runs --> 1975 CB550-K1
Projects ---> Crusty old boat
Gallery --> http://www.sohc4.us/gallery/v/members/personal/Christopher/?g2_navId=xada3c7ff
Offline Mark M
  • This is what the 10 year old me wanted for Xmas
« Reply #2 on: October 11, 2006, 01:52:02 PM »
The ironic part is the extra friction added to the system by this cable can cause the throttle to stick open >:(
When you lube the cables make sure you do both of them.
In the UK anything over 40 years old only needs insurance and Fuel.
Offline 6adan
« Reply #3 on: October 11, 2006, 09:13:14 PM »
You know a push cable just dose not make sense to me.It would if the inner part of the cable was a solid wire,but with a stranded cable I don't think you could not push the throttle closed.Dannie
1970 CB750 JDM,1975 GL1000, 1979 GL1000, 1979 CBX, 1995 GL1500, 2000 GL1500CT Valkyrie, 2008 GL1800 Trike.
Offline Jv550
  • '75 CB 550 K
« Reply #4 on: October 11, 2006, 09:37:50 PM »
Mine's disconnected...
That's like hypnotizing chickens...
Offline mrbreeze
  • Not your average
« Reply #5 on: October 11, 2006, 10:00:31 PM »
I took my return cable off 2 yrs. ago.No problems. Have you looked at that return spring? Its a stout mofo and I can't see it breaking.Its like the ones we used to have on our old carbureted autos. Has anyone here ever heard of one breaking?
MEMBER # 257
Kelvin8
« Reply #6 on: October 11, 2006, 10:09:10 PM »
6Adan
the return cable doesn't push, it pulls, so stranded is fine.
Why? yeah, I ask that every time I pull my carbs.
kelvin8
Brunow
« Reply #7 on: October 11, 2006, 11:16:09 PM »
Yeah!
There was no gas return cable, so i don't need to install one!
That save's my 15€  ;D
Thanx!
Offline IndianRider
« Reply #8 on: December 21, 2006, 06:04:34 AM »
how do you re -install that stout carb return spring ? it is damn tough to get it back on ... what are the 2 points to where the ends of the spring need to hook onto ?? any tricks for easier installation?  im thinking of getting a similar lighter spring ...
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #9 on: December 21, 2006, 06:29:00 AM »
The k0 didnt have a return cable. Subsequent models did.
No.
kettlesd
« Reply #10 on: December 21, 2006, 10:21:48 AM »
I run with one cable too, for the aforementioned extra friction that the second cable imparts to the whole setup.
Has anyone EVER had a throttle spring break on them?????????
Offline Jinxracing
  • It's hot shit, not
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #11 on: December 21, 2006, 10:47:44 AM »
Man, that is some good news. Thought I was going to have to keep the second cable in there. Don't modern bikes just have one cable? They seem to get along just fine.
Seems to me that two return springs, each with half the tension of the original spring would be the safer & paranoid (me) way to go.  ;D That way if one breaks, you still have some return tension–possibly saving your bacon.
–Captain Horatio Hornblower
www.thehairynickel.com
Offline dusterdude
« Reply #12 on: December 21, 2006, 11:54:11 AM »
i`d like to break mine
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
kettlesd
« Reply #13 on: December 21, 2006, 12:03:34 PM »
However, by removing the push cable, I'm sure that would void the warranty !! ;D ;D ;D ;D ;D
Offline crazypj
  • I'm brill, me
« Reply #14 on: December 21, 2006, 01:15:00 PM »
If the cables are lubed correctly the ONLY reason throttle sticks is the cables adjusted too tight.
The friction is the throttle grip/housing being pulled onto the bar. You need a little slack in BOTH cables.
I've run the 550 for at least 80,000 miles with only one cable and never had a problem with sticking
PJ
Offline mrbreeze
  • Not your average
« Reply #15 on: December 21, 2006, 07:42:25 PM »
I'm purty sure mine's already out of warranty!!!
MEMBER # 257
