Author Topic: Removing a broken stud  (Read 1950 times)
Offline eigenvector
« on: February 21, 2015, 12:58:39 PM »
I have an exhaust stud that broke off INSIDE the mounting hole.  About a 1/4" inside.
How would you go about removing that?  Would an easy out work here or is that too far in the hole for something like that to work?
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Re: Removing a broken stud
« Reply #1 on: February 21, 2015, 01:23:44 PM »
I have never seen an easy out that worked. Get a left hand drill bit and try to drill it out, chances are it will spin it out.
« Reply #2 on: February 21, 2015, 01:51:30 PM »
Agreed, never seen one work. Problem as I see it, when you turn an EZO counterclockwise to remove the bolt, it expands the bolt into the hole and fights against itself, breaking almost always.
A reverse drill removes material while coaxing the broken piece to rotate in the correct direction. And short of that, simply drilling it out, little bit at a time, often works. Getting a good start is the problem, especially when as yours is the break is down in the hole.
OFten the threads will be destroyed calling for a thread repair.
Offline eigenvector
« Reply #3 on: February 21, 2015, 02:22:53 PM »
I'll take a look at finding a reverse drill then.
I'm going to take a bit of time off, I've made big strides today - don't want to F it up by rushing forward.
I removed the rest of the studs since I have to order a new set anyway.  I was amazed how simple they came out.
Rob
1977 CB550K
1983 VF750S Sabre
Offline chewbacca5000
  • I polish covers!
« Reply #4 on: February 21, 2015, 02:58:28 PM »
Harbor Freight sell the reverse drill bits.  I have used them and they work.  Make sure you have a centre punch to keep the bit from wandering.  Be sure to us a bit that is alot smaller than the stud.  Drill and if it comes out great.  If not go to the next size up.
Is it in a location that you can get at square?  An angle will not work.
« Reply #5 on: February 21, 2015, 04:05:18 PM »
The best way is EDM, but new used head would be proly cheaper than that.
Offline Airborne 82nd
« Reply #6 on: February 21, 2015, 05:36:50 PM »
You might want to get this. The first step is the most important one. so is the tool.  (self centering drill bit)
http://www.homedepot.com/s/self+centering+drill+bit?NCNI-5
This is just the first one that pooped up. I go with quality first. So pick your weapon of choice.
  • I polish covers!
« Reply #7 on: February 21, 2015, 06:27:23 PM »
Those look pretty nice.  Are they a drill bit with a sleeve?  How do they self centre?
« Reply #8 on: February 22, 2015, 04:38:32 AM »
They look like drill bushing attached to a bit, great idea.
Offline grcamna2
« Reply #9 on: February 22, 2015, 06:24:33 AM »
I've got to learn that if it's at all possible to flatten the broken bolt/stud on the end as much as possible before I drill STRaight.   :o  ::) :D been there done that.  ;)
  • I polish covers!
« Reply #10 on: February 22, 2015, 06:27:36 AM »
I had a broken stud problem once, but not in the hole like op.  Was able to weld a large nut to it and use a screw driver as a handle to get the stud out.
Offline koendd
« Reply #11 on: February 22, 2015, 11:42:00 AM »
I've never had success with drilling holes and reversing them out...
I had 3 studs breaking when removing them from my cases.
one of them was inside the cases as well, I just welded on it till the welds got "out" of the case and the welded a nut on that.
then let it cool down and used a impact wrench to get them out.
good luck  ;D
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Offline eigenvector
« Reply #12 on: February 22, 2015, 12:28:54 PM »
I have it worn down at this point.  I'll see if I can use a 6mm tap to get the threads back in shape, barring that I might have to oversize to 8mm and open the exhaust clamp hole to 8mm.  Not my first choice of course but I don't even see evidence of threads in this hole - almost looks like it was welded. :'(
Incidentally - Speed Out, you know those drill bits that back out stripped screws?  Useless as a third nipple.  Might work on stripped screws - but hardened bolts, nope.
Rob
1977 CB550K
1983 VF750S Sabre
Offline markb
  • When I finish my current project I might be a
« Reply #13 on: February 22, 2015, 02:59:28 PM »
Agreed, EDM is the best especially when it's below flush.  I've paid between $25-40.  Maybe you could get a used head for that.  Best part is no headache and only time spent is dropping it off and picking it up.  ;)
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
« Reply #14 on: February 22, 2015, 03:03:49 PM »
That is a good price, i never had to research it. Good to know.
