Author Topic: 400f oil cooler plumbing without sandwich plate  (Read 2704 times)
Offline Speedy Siegl Racing
« on: February 23, 2015, 02:00:29 PM »
Hello All, first post here!
I am in the process of stage 2 on a good friends honda cb400f. Stage 1 was a Yoshimura 466 kit, cometic head gasket, mild porting, dyna ignition and 3 ohm coils, and a JMCA/Yoshimura exhaust.
Stage 2 is adding CR26 carbs (re-racked with the throttle linkage between carb 1 and 2), a Web Cams hot street cam, CB750 oil pump mod, and an oil cooler.
My question for you is, what is the best way to plumb the oil cooler WITHOUT using the typical sandwich plate? The Yoshimura exhaust does not allow you to remove the oil filter with it in place, and there is no room to extend it out, and buying a more friendly exhaust is not an option. I am fine with drilling and tapping a passage, or welding a bung on somewhere, I would just like to see if anyone else has done something similar that I can learn from.
Thank you!
Re: 400f oil cooler plumbing without sandwich plate
« Reply #1 on: February 23, 2015, 02:16:18 PM »
It's not answering your question, but is there room for a plate and convert to a narrower spin-on filter?
Offline ttr400
    • ttr400 Projects and Billet parts.
« Reply #2 on: February 23, 2015, 02:38:23 PM »
The way i did it with the yoshimura exhaust is to weld a bung into the oil filter housing to accept a AN6 fitting. plus also a bung to accept a the AN6 fitting at the oil pump side.
looking at the pump, the lower l/h side is the main feed to the oil filter, i welded a TTR fitting into the pump to re-direct the feed. this blanked off the feed to the filter. you could also remove the pressure switch and use this as the main feed (drill and re tap, M12x1.0. if using my TTR fittings)
So:
From oil pump to oil cooler.
From oil cooler to oil filter
Don't have any decent pics but here are a couple i found.
Note: I also used my TTR400 uprated oil pump to increase the flow.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Offline Tintop
« Reply #3 on: February 23, 2015, 07:54:09 PM »
My solution to the same issue (tight pipes) was slightly different.  Pics are here - http://forums.sohc4.net/index.php?topic=83937.0
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
« Reply #4 on: February 24, 2015, 08:12:59 AM »
Thanks guys.
Tell me more about the spin on filter idea: How much room does a sandwich plate and spin on filter take up? If it is the same as the stock +1/4", that would probably be the easiest way.
If that does not work, I will do what Kevin outlined.
Thanks again!
Offline Tim2005
« Reply #5 on: February 24, 2015, 12:06:15 PM »
Slightly off topic, but I notice you say "CR26 carbs (re-racked with the throttle linkage between carb 1 and 2),"  Are you sure that's aok?  I've only ever seen them on a 400f (mine included) with the throttle linkage outside carb#4.
We are talking Keihin CRs, presumably?
« Reply #6 on: February 24, 2015, 02:16:39 PM »
The plate is 1.5" thick, the Honda filter is 3.25"OD x 3.25" long. Best picture I could find.
« Reply #7 on: February 25, 2015, 08:13:43 AM »
Tim,
Anything is possible, but its not easy. You have to tap the #2 carb for the cable plate screw, remove the carb shaft and drill a new hole for the roll pin on the linkage. Im not finished yet, but I learned about it trolling this forum!
Thanks Bwaller for the pic and dimensions, Ill measure the stock filter and cross my fingers that it is as long as your setup!
Offline brandEn
« Reply #8 on: February 25, 2015, 08:32:12 AM »
Hey is this Tower from twinline? If so just wanted to say he is a good dude. He helped tweakin and I dial in our CR carbs with the help of Doctor D on his shops dyno.
« Reply #9 on: February 25, 2015, 11:08:29 AM »
Haha thanks Branden! This is Isaac, not Tower, but we will be sharing this account to post work and/or ask questions here and there. Ill pass your compliments on to him!
Offline brandEn
« Reply #10 on: February 25, 2015, 12:05:24 PM »
Right on!  :)
Offline Kevin
« Reply #11 on: February 26, 2015, 03:53:13 PM »
Tim,
Here's more info on how to move the throttle on the CR Carbs:
http://forums.sohc4.net/index.php?topic=42903.50#lastPost
Isaac, good luck on your project! Looking forward to seeing it around town, sounds pretty sweet!!
A couple of 400F's and a
'98 Suzuki Intruder VS1400 ~ for long rides
