Author Topic: Possible Dyna 2000 issue??  (Read 3567 times)
« on: February 23, 2015, 04:05:53 PM »
I use a Dyna 2000 on my CB750.  The following has twice stranded me on my bike:
Bike loses spark and stalls in the middle of crusing at highway speed after about 1.5 hours of riding.  When I restart, the bike revs (with no throttle input) up to about 3500 rpm and then stalls again.  I cannot keep the bike running.  After an extended wait (1 day), the bike fires and runs.  It only happens after a thorough run.
I am wondering if the Dyna box is overheating, although mine is located away from any heat sources with a source of cool air.  No loose wires and plenty of gas.
HAS THIS HAPPENED TO ANYONE ELSE?
Re: Possible Dyna 2000 issue??
« Reply #1 on: February 23, 2015, 04:20:57 PM »
The "turning it back on and it revs" is a symptom of fuel starvation, sure your tank breather is all good...?
« Reply #2 on: February 23, 2015, 04:23:50 PM »
Mick,
That's what Dynatek thought, too.  I'll double check the vent on the cap.  Petcock seems to have no clogs.
« Reply #3 on: February 23, 2015, 04:44:06 PM »
Mick,
Check fuel lines  and filters too mate... ;)
« Reply #4 on: February 23, 2015, 04:47:13 PM »
Thanks, Mick.
« Reply #5 on: February 23, 2015, 05:42:26 PM »
What kind of gas tank do you have? When it stalls you might check for fuel in the bowls or pull a plug and check for spark?
It's the crank triggers that overheat. I lost one at a time, twice, that with a slotted ign cover to prevent overheating. Both times the bike would start & idle but break up at about 5500.
Online scottly
« Reply #6 on: February 23, 2015, 05:47:51 PM »
Bike loses spark
Usually when Dynas fail, spark is lost on 2 cylinders. Have you verified a loss of spark, or are you guessing that's why the bike died?
« Reply #7 on: February 23, 2015, 07:42:51 PM »
Mine died on me and I assumed the worse. Turned out that the alternator rotor was not tightened down and spun loose.
Offline pickle fart
« Reply #8 on: February 23, 2015, 08:27:33 PM »
Main jet is plugged or partially plugged.
Offline buffalogt750
« Reply #9 on: February 25, 2015, 05:18:24 AM »
It takes an hour and a half of running for a fuel starvation problem to show itself and a full day before it runs right again?
1976 Honda CB550K   SOLD
1993 Ducati 750 SS
2000 Suzuki Bandit 1200
Offline tweakin
  • tear down
« Reply #10 on: February 25, 2015, 07:03:07 AM »
I have had the same experience with the 2000.  Added some air vents in the ignition cover on the K1 to hopefully prevent this moving forward.
« Reply #11 on: February 25, 2015, 02:40:09 PM »
It was a suggestion, whats yours...?
Offline Spanner 1
« Reply #12 on: February 25, 2015, 07:43:51 PM »
Run for 1 1/2 hours before fuel starvation ?....... absolutely. Filled the tank on my K8 750 in Cleveland TN heading home to Nashville TN ( 160 miles ). Went for almost 2 hours and the bike died. Thought I had hit reserve, so flipped it over to Res. and it wouldn't start. Opened the gas cap to see how much gas was in there , closed cap bike started right up... rode home the rest of the way no problem ( stock ign., btw )  I figured later that the fuel level dropping from full to close to reserve without the gas cap being opened even once created a vacuum in the tank which eventually stopped fuel flow..... :)
