Author Topic: Stupid chain question  (Read 1833 times)
Offline theslayedsaint
« on: February 25, 2015, 08:45:51 PM »
Ok I over tightened my connecting link for my X ring chain. Do I need to cut it off and replace or can I some how losen it? I haven't yet "closed" the link or whatever you call it when u cramp the two pins.
1974 CB750 custom build cafe racer
-849cc big bore
-Webcam 63a
-APE rods
-4-1 stainless exhaust
-GSXR front end
Offline heyitsrama
Re: Stupid chain question
« Reply #1 on: February 25, 2015, 09:26:34 PM »
Can you post an image please? Just want to get a better look at it.  ;)
_____________________________________________________________________________
72' cb500
I can't believe it's not butter.
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #2 on: February 25, 2015, 11:59:08 PM »
Mate, I'm all for people doing things for themselves but you're worrying me :o
This is one of those jobs that once shown you'll be able to do no problem in the future. Easy, but also vital to get done correctly. You don't want that chain letting go at speed.
That said, I can't imagine you've done anything that can't be rectified. If by 'overtightening the link' you mean you've just compressed the side plate more than it needs, then yes just dismantle and start again. Hopefully you won't have damaged the seals (x-rings). If you seriously believe you need to cut it off then I can't imagine what you've done! The side plate is probably just binding on the pins where it's gone on slightly cocked - patience and judicious use of levers/ screwdrivers/ WD40 should do it.
When it comes to rivetting the pins, make sure you have the correct tool. Plenty of videos on YouTube showing how to do this, or better still have someone show you if it's your first time. Good luck, all part of the fun!
Build threads:
1977 CB750 F2
1958 Norton Model 99
« Reply #3 on: February 26, 2015, 12:34:06 AM »
Thanks... I think
Sorry I thought this was a place to ask and answer questions my bad! And yes I am using the right tools and yes the plate was just binding up and didn't seem to move as freely as the other links nothing more. So before I did what I thougt was the right thing, I thought I would double check. But thanks for the info, sorry that my qustion worried you! Guess I'm one of thoses people that ask before they do somthing they've never done before.
-849cc big bore
-Webcam 63a
-APE rods
-GSXR front end
Offline Airborne 82nd
« Reply #4 on: February 26, 2015, 12:46:35 AM »
You did come to the right place so just ask away. ;) Just be ready for all the answer This is the www with people from all over the world that word things differently. I think you will be fine as long as you did not screw up the xrings.
Offline Bodi
« Reply #5 on: February 26, 2015, 12:56:43 AM »
This is indeed the place to ask questions! These chains are harder to join than unsealed chains but the basic process is the same. I have had them be stiff at the master after joining with the link installed properly, and free up after a bit of riding. Not locked really tight: just considerably less flexible at the master link.
I've also had to replace one chain where something went wrong - I didn't install the link but I think it had been "riveted" with a large vise and the master pins mashed.
The worry is for your bike... and your life - a broken chain will usually damage 750 engine cases (not so much on other models), the chain itself can injure you or someone else, and suddenly coasting with no chain is dangerous in traffic.
« Reply #6 on: February 26, 2015, 02:53:32 AM »
I have seen tools with a distance plate to use when pressing all together to avoid rivet it too hard, squeezing the o/x-rings. My tool does not and I finally did everything correct with 3:rd master link.
Too hard first time that did not correct itself despite 1500km driving, new link and when ready I saw one x-ring on the floor that had jumped off... 3:rd time OK.
Very good idea to have 2-3 extra master links. ;)
Offline ofreen
« Reply #7 on: February 26, 2015, 06:22:10 AM »
The master link sideplate is a snug press fit as you have found out. If it is on too far you probably can take a punch and a hammer, put the link on the rear sprocket, and tap on the pins to back it off a little. You don't want hit too hard as you will mushroom the pins, but with a little finesse you should be able to back it off. When pressing them on, measure the width of a fixed link with a caliper. Then proceed slowly with your chain tool until the width matches the fixed links. Make sure it is going on straight.
Greg
'75 CB750F
« Reply #8 on: February 26, 2015, 06:27:35 AM »
Thanks a bunch everyone! I'll look at it again today and go from there.
-849cc big bore
-Webcam 63a
-APE rods
-GSXR front end
« Reply #9 on: February 26, 2015, 06:44:06 AM »
Not helpful at this point but my Regina chain came withi a distance plate to keep one from pushing the sideplate on too far.
As to pulling it away, I'd think a chain breaker should do the trick without any leveraging or tapping or worse.
Offline martin99
  • UK Based, Non-
« Reply #10 on: February 26, 2015, 08:38:18 AM »
Thanks... I think
I didn't mean anything by my reply mate, sorry if I offended you. None of us know what skills and experience anyone else has on here, and had you been a noob I don't think I was wrong in emphasising the safety aspect. Hope you get it fixed, and yes this is absolutely the right place to ask questions!
Build threads:
1977 CB750 F2
« Reply #11 on: February 26, 2015, 11:01:03 AM »
The distances seems to follow some chains and master links. Photo with 2 E shaped distances for both sides. To be removed when chain is riveted together
« Reply #12 on: February 26, 2015, 05:44:03 PM »
Ok fare enough, guess you can call me a "noob" for wanting to ask qustions. A lot of qustions may make me sound dumb but in fact it's the people that asume they know all the answers and in fact don't that end up on the side of the road in a ditch. Again my qustion was only if I over tighten the plats is it still ok to use. In my defense I thought it would be fine after I road the bike. But hey it's a 849cc bike with two wheels that if anything goes wrong is a bad thing, so I thought I'll ask to double check, if that makes me a noob then by all means Its ok with me.
« Last Edit: February 26, 2015, 05:49:10 PM by theslayedsaint »
-849cc big bore
-Webcam 63a
-APE rods
-GSXR front end
Offline martin99
  • UK Based, Non-
« Reply #13 on: February 26, 2015, 10:54:01 PM »
I did not call you a noob. I don't see how I upset you, but clearly I did and I repeat my apology. Any question from anybody is valid on this site. Lets move on.
Good luck with the bike, hope it'll be up and running soon.
Build threads:
1977 CB750 F2
« Reply #14 on: February 28, 2015, 05:17:30 PM »
its all good martin99 sorry i snapped back moving on to better things.. or just more work on the damn headache of a bike. and don't worry calj737 i'm very thankful of my youth has I see it moving by so fast.
-849cc big bore
-Webcam 63a
-APE rods
-GSXR front end
Offline eigenvector
« Reply #15 on: February 28, 2015, 10:47:38 PM »
I recall seeing the bike in your post, but you might want to check the fit of the chain around the primary shaft.  I recall some posts here about O-ring and X-ring chains rubbing on stuff around the gear box.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
« Reply #16 on: March 01, 2015, 08:31:43 AM »
O thanks, i'll take a better look at it later didn't notice it when i first put it on but haven't tightened it all up yet.
-849cc big bore
-Webcam 63a
-APE rods
-GSXR front end
Offline eigenvector
« Reply #17 on: March 01, 2015, 08:33:46 AM »
For what it's worth I run an o-ring chain on mine and so far as I can tell it isn't rubbing so it may be something limited to specific versions.
Rob
1977 CB550K
1983 VF750S Sabre
