Author Topic: Oil Gallery Plug/Nut/Cap very tight stuck  (Read 1137 times)
Offline AndyN
« on: February 25, 2015, 11:13:06 PM »
Hi, having issues getting this one loose. I looked through Honda shop manual and it seems like it should just unscrew. The aluminum is soft and don't want to strip the nut head. I'm going to put some heat on it.
Any other ideas?
Thanks
Offline MickB
« Reply #1 on: February 25, 2015, 11:24:12 PM »
Andy if it's a cap try spraying some PB and leave it soak, they do have an O ring and a thread on them, if the PB doesn't work maybe a try a little heat, heat will move most things seized.
If it's a plug PB and then heat.
If you're pulling the engine down you'll be able to punch it out from inside the engine.
« Last Edit: February 25, 2015, 11:27:30 PM by MickB »
Re: Oil Gallery Plug/Nut/Cap very tight stuck
« Reply #2 on: February 26, 2015, 04:41:25 AM »
Use a six point socket.
Offline koendd
« Reply #3 on: February 26, 2015, 05:28:35 AM »
Heat and this worked for mine:
messed up the "bolt" a bit, but it's the bottom one so not really visible anyways...
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Offline AndyN
« Reply #4 on: February 26, 2015, 07:43:21 AM »
Thanks Gents... I will try your recommendations and post the results. :-)
I plan on putting on a oil pressure gauge in place anyways, so I'm not concerned about "saving" the bolt.
Online Don R
« Reply #5 on: February 26, 2015, 07:58:29 AM »
Put a 6 point on it, add some pressure on the wrench and tap on the side of the casting with a hard  plastic hammer. They usually break loose. This method works on a lot of things, including brake bleeders.
Offline AndyN
« Reply #6 on: February 26, 2015, 08:03:57 AM »
It came right off, though I put some PB on it a couple days ago.
I did use the pipe wrench around the outer edge of the plug/cap and with very little effort it broke free.
Thanks all.
Andy
Offline AndyN
« Reply #7 on: February 26, 2015, 08:07:18 AM »
Oh, one other note...with what DonR said with a 6 point. I found this alligator socket does wonders too :-)
Thanks again
