Author Topic: 79 CB650 Cafe Rear set  (Read 3458 times)
Offline CBR954AD
« on: February 26, 2015, 08:26:09 AM »
Morning CB lovers,
I am half way in building my first cafe bike. I have a few questions about parts that I need to order.
1- I want to run Rear Sets
What kind can I use? I heard rizorro or pretty much OEM cbr600 would work. but how do I connect the shifter linkage? here is a few that I found. can anyone provide pictures of write up how to make rear sets work I already have the mounting brackets, same for rear brake how to connect it. I will be using stock drum setup of a 750 wheel hub assembly
this one comes with the linkage that goes to the transmission shaft
http://www.ebay.com/itm/261474155764?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
this one has 2 linkages
http://www.ebay.com/itm/131332888230?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
and number 3
http://www.ebay.com/itm/171095584222?_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Re: 79 CB650 Cafe Rear set
« Reply #1 on: February 26, 2015, 01:22:44 PM »
The problem is all of those are made for bikes with a rear disc and thus the brake pedal can be easily linked to a master cylinder, but to actuate a drum you are gonna have to get very clever or cut and weld.  Here is the brake side on my cb750...
550 etc 046 by seanbarney53, on Flickr
I think bolt on rearsets for the cb650 are available from Raask...
Offline CBR954AD
« Reply #2 on: February 26, 2015, 04:14:55 PM »
What about the clutch side any pix or how to connect. Is Raask a company? Thank you
« Reply #3 on: February 26, 2015, 04:59:35 PM »
found one...can be seen at the very bottom of the page, last post
http://forums.sohc4.net/index.php?topic=80592.200
yes, Raask is a company.  I just tried to find them for sale somewhere, and it seems they have disappeared off the face of the earth.  Mikes XS used to be the main dealer in the U.S., but I could not find them there.
     Since you already have brackets, I would suggest getting the Universal Tarrozi rearsets.  Fast from the Past sells a wide variety of linkage rods and parts to fit them to many bikes.
http://www.fastfromthepast.com/16-0010
http://www.fastfromthepast.com/rearsets/rearset-parts
Offline CBR954AD
« Reply #4 on: February 26, 2015, 05:05:08 PM »
Yes but arnt the tarrozi just like any other rear set i was looking at the pic i dont see the difference
Offline CBR954AD
« Reply #6 on: February 26, 2015, 05:11:33 PM »
Wow thanks that helped, from looks of i probably make owm pedal and shifter. On that link it looks like. A home made kit
Offline CBR954AD
« Reply #7 on: February 26, 2015, 05:13:46 PM »
Wow ill buy the OZ left one if i can find a matching right, also item is from a hawk 650 maybe. I could search for those on ebay
« Reply #8 on: February 26, 2015, 05:24:17 PM »
The difference is Tarrozi actually has the parts so that you can actually connect the levers to your bike...that is what you were asking about isn't it?
Offline CBR954AD
« Reply #9 on: February 26, 2015, 05:51:57 PM »
Oh i didnt see that , if thats case i will just order set. Let look at em again
« Reply #10 on: February 26, 2015, 05:56:37 PM »
You have to look through all the pages in that second link...there are lots of replacement parts for the bolt on stuff, but by about page 7 there are brake arms, shifter arms, linkage rods, heim joints etc.  I would even call Fast from the Past as they might be able to set you right up with everything you need.
Offline CBR954AD
« Reply #11 on: February 26, 2015, 06:13:23 PM »
Thank u, i just looked at cognimoto terozzi ones they make for 750 which is what i need. My bike is a 650 but frame is identical to 750, and im using a 18'DID A750 drum rear wheel
« Reply #12 on: February 26, 2015, 06:20:12 PM »
pretty sure it is not...but may be close enough.  Hopefully Cognito guy knows what is involved, as I sure have never owned a 650...
Offline CBR954AD
« Reply #13 on: February 26, 2015, 07:00:54 PM »
Ive been told frame in 78,79 650-750 identical only difference is the swing arm because the 750 a uses disc brakes
Offline CBR954AD
« Reply #15 on: February 26, 2015, 08:29:30 PM »
Maybe thats what it was
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #16 on: February 26, 2015, 10:13:43 PM »
You're never gonna find direct bolt on CB650 rear sets. There are several ways to address the issue and each will have compromises.
You can certainly adapt modern rearsets by way of braze on mounts on the frame and adapted linkages or you can fabricate universal adapters like these that pick up engine and swingarm pivots.
