Author Topic: New Project: Just Picked up a 1981 CB650 stripped down to the frame  (Read 900 times)
Offline fordhamr
Thanks for the add!
Got the 1981 CB650 as a frame, motor and box of parts! Bough from a sheriff that promised it was running good when disassembled. Frame came painted so this weekend I slapped on the front and rear wheel!
I hope to install the motor this week!
Any pointers for installing the motor would be greatly appreciated! Trying to make a check list of things to check and fluid to fill! :)
Thanks!
I look forward to asking MANY questions along this project as forums can be a HUGE resource and big help!
Offline chewbacca5000
  • I polish covers!
Re: New Project: Just Picked up a 1981 CB650 stripped down to the frame
« Reply #1 on: March 02, 2015, 02:54:38 PM »
It is easiest to lay the motor over the fame and install the engine bolts and go from there.
Offline mrfish2
  • I might be a
« Reply #2 on: March 02, 2015, 07:38:17 PM »
I'm not sure about the 81, but my 82 Nighthawk has a removeable lower part of the frame on the right side that allows for easy removal/installation of the engine. More knowledgeable minds than mine can say for sure about the 81 frame.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
Offline JimJamerino
  • Yay! I'm a
  • Not rich enough to be "eccentric."
    • My CB650C build thread
« Reply #3 on: March 03, 2015, 10:03:30 AM »
On my '80 CB650 the lower right rail of the frame unbolts. Two bolts through the motor mounts, two bolts roughly behind the brake pedal. It allows removal/installation of the engine with the oil filter in place. I found that laying the engine on its side and lowering the frame over it was pretty effective. I bolted up the left side motor mounts, then stood it up, replaced the rail, and bolted in the right side mounts.
Also, I found it easier if the frame was all alone... no wheels, handlebars, fork, or anything else. I was able to lift the back end to put a wheel on, then used the center stand and a jack under the motor to lift the front end to put the front wheel on.
~ Jim
formerly "emperorspartacus"
There are old bikers.  There are dumb bikers.  There are no old, dumb bikers.
My CB650C rebuild http://forums.sohc4.net/index.php?topic=74212.0
Offline CBGriz
« Reply #4 on: March 08, 2015, 12:41:53 AM »
+1 on this method! '82 and '79 CB650 engines out and in this way. Little bit of a pain but I left the wheels on. Still easier than trying to lift it in all my lonesome.
