Author Topic: Magnesium wheel crack test?  (Read 2813 times)
Offline DYSKORD
« on: March 05, 2015, 04:58:01 PM »
Anyone know where to get a set of MAGNESIUM wheels
crack tested?
Offline Powderman
Re: Magnesium wheel crack test?
« Reply #1 on: March 05, 2015, 09:06:00 PM »
Check your local listings for "magnafluxing"
Offline DYSKORD
« Reply #2 on: March 06, 2015, 12:40:50 PM »
I was under the impression you couldn't magnaflux magnesium. I think I had read that it won't show internal cracks and therefore need to be sent through an x-Ray.
Offline Bodi
« Reply #3 on: March 07, 2015, 06:54:21 PM »
From limited experience with race car wheels, the problem is surface cracking that can cause catastrophic failure under stress. I never heard anything about internal cracks. We used a fluorescent spray and a UV lamp for periodic inspection: spray, wipe, go somewhere really dark, inspect with UV light: the spray sticks in any cracks and they showed up very bright green. The cracked wheels (not many but not unknown) made nice coffee table bases with a disc of glass.
Offline Powderman
« Reply #4 on: March 08, 2015, 08:51:47 AM »
I don't know of any test that will reveal internal cracks. Magna fluxing is done using a magnet so that's why it isn't used on Magnesium. Magnaflux also makes a dye, as mentioned in the post before this one, for checking for surface cracks on mag.
« Reply #5 on: March 08, 2015, 09:07:10 AM »
Non Destructive. Testing.   NDT it is called..  Seach Yellow Pages or online.
« Reply #6 on: March 09, 2015, 12:34:02 AM »
 tap it and see if it rings.
Offline chewbacca5000
  • I polish covers!
« Reply #7 on: March 11, 2015, 05:07:08 PM »
Like I said before I will volunteer to test them out for you.  if  they don't fall apart at a 125 they should be good to go.
Offline LesterPiglet
  • 1977 CB550F2
