Author Topic: 18" rear rim for 78CB750K  (Read 893 times)
Offline Ridgerunner
« on: March 06, 2015, 06:30:23 AM »
Has anyone laced an 18" rim to the stock rear hub?  If so what rim did you use?
"Good sense is the enemy of creativity" Pablo Piacaso
Offline itskohler
Re: 18" rear rim for 78CB750K
« Reply #1 on: March 06, 2015, 06:44:27 AM »
Interested in this as well.
JWExperience
« Reply #2 on: March 06, 2015, 02:52:50 PM »
Not sure how it's not possible. I laced a 18" Excel onto my 76' as that is the stock size.
'76 cb750k, '78 cb750f 'Merica Edition
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #3 on: March 06, 2015, 05:28:02 PM »
The later models came with 17" rims. You can get a new 18" rim and lace it to your hub, or you can get a stock 18" wheel from an earlier model. Just be sure to use your sprocket carrier and spacers since the later model sprocket carrier is different than the earlier ones. Everything else (including brakes) is the same. I swap back and forth between 17" and 18" rear wheels on my K8. There seems to be a wider selection of 18" tires.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
