Author Topic: Need new chain  (Read 748 times)
Offline Kustomizer
Need new chain
« on: March 07, 2015, 06:39:25 am »
Just wondering what length chain I need to get for my 1976 CB750?
Offline Ravie
  • Definitely not a
  • Soul to Soul
Re: Need new chain
« Reply #1 on: March 07, 2015, 04:46:52 pm »
Do you have the old one?  If so, measure it. If you have 17/48 sprockets it may have been a 100 link chain. You could do a 102 safely with that setup. Mine had a 100 link on it so that's what I'm replacing it with.
I'm using a D.I.D. (Daido) chain, but I've read Diamond recommended several times.
After much reading, I would personally not recommend O-ring type chains. Seem like more trouble than they're worth and you get less HP to the rear wheel. No thanks.
1975 CB750K5 Rebuild in progress.
http://forums.sohc4.net/index.php?topic=139072.0
Offline guitarkev66
Re: Need new chain
« Reply #2 on: March 07, 2015, 05:48:41 pm »
Yes I too heard Diamond chains are very well built but very pricey.  I just had a fellow very knowledgable sohc4 forum member tell me he went o ring for his restored K1 and loves it no maintenance.  530/102link
1970 K0 CB750 JDM Blue
1972 K2 cb750 Gold
1970 K0 cb750 Blue
1970 K0 cb750 gold
1970 K0 cb750 red
1971 K1 cb750 gold
Re: Need new chain
« Reply #3 on: March 07, 2015, 06:23:25 pm »
Easy decision: Do you intend to ride a lot, like more than a couple thou a year, and in multi hundred mile bites? and: Do you hate to get your hands dirty while on a trip? You'll love the ORing chain. The mileage rob is a point of contention. Google the issue and you'll get results all over, many saying there is no loss.
All modern production motorcycles that use a chain, use an ORing chain. ANd many of them are very horsepower conscious.
I was once a non believer, but having been experienced to one, on my hawkGT, I'll never go back. OVer 25,000 miles without an adjustment, and very little chain lube.
Offline Kustomizer
Re: Need new chain
« Reply #4 on: March 07, 2015, 07:44:21 pm »
Great, thanks for the info!
Re: Need new chain
« Reply #5 on: March 07, 2015, 08:17:42 pm »
For my F3 (17/48) I bought a 110link 530, and cut 4-5 to get the length I wanted.
Re: Need new chain
« Reply #6 on: March 08, 2015, 12:31:52 am »
My CB750K6-76 has allways got 100 links. Last chain is a DC chain, 530 MZX Heavy Duty QX-Ring Gold with really tough solid master link. The same chain today has hollow link which is MUCH easier to rivet. The solid link need a special too, very expensive while the hollow link does not need much force so the cheap tool can be used.
I know since my first cheap tool broke, link still not riveted by the tool, a DID copy. I had to purchase an expensive Whale tool that hammer the rivet end.
Go for hollow link, buy 1 or 2 extra master links. Easy to rivet too hard .
Re: Need new chain
« Reply #7 on: March 08, 2015, 07:20:37 am »
Most ORing chains have an alternative clip link. The side plate still needs to be pressed on, but it can be done with a pair of nuts and some vicegrips. Other than that, the clip type is a cinch to install.
Re: Need new chain
« Reply #8 on: March 08, 2015, 09:49:50 am »
I never had any problem with the old clip type. I used DID 50HDS o-ring chain
No need of expensive riveting tool. Easy to remove chain too.
