Author Topic: 1978 CB750K oiltank mount rubber  (Read 976 times)
Offline SKTP
« on: March 09, 2015, 10:16:32 AM »
So it would appear that the rubber is available (and the weird metal threaded parts). I want to repaint my oil tank...
So the question is; How to these come apart? I want to remove the rubber for paint
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Re: 1978 CB750K oiltank mount rubber
« Reply #1 on: March 09, 2015, 10:25:57 AM »
haha...those are a non-stock PO hack job!  ;D
just cut them out i guess....
rubber grommets for side cover mounting should not have those metal inserts.  How do your side covers mount?  ;D
http://www.partsnmore.com/parts/honda/cb750/?filters%5Bcategory%5D=hardware
the other three hard black plastic are to mount the tank to the frame. They should have smooth metal bushings inside.
« Last Edit: March 09, 2015, 10:29:52 AM by flybox1 »
Offline SKTP
« Reply #2 on: March 09, 2015, 10:39:54 AM »
Its a 78 Flybox...the oil tank side uses 3 screws to hold on the plastic cover
I think your link is for the MUCH nicer looking 69-76
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
« Reply #3 on: March 09, 2015, 10:42:09 AM »
http://www.bikebandit.com/oem-parts/1978-honda-cb750k/o/m9458#sch401652
Oh wait?!!! You are right I think...What the heck??!!!!
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
« Reply #4 on: March 09, 2015, 10:45:41 AM »
I have a '78 as well.
you're method of attaching your sidecovers is what is incorrect ;) ;D
« Last Edit: March 09, 2015, 10:54:12 AM by flybox1 »
« Reply #5 on: March 09, 2015, 10:59:43 AM »
Aftermarket side covers ??
Offline mcpuffett
« Reply #6 on: March 09, 2015, 11:02:32 AM »
Maier type side covers use the screw and nut method  ;), just  push the metal insert out of the rubber grommet then push the grommet out of the mounting hole  ;) cheers Mick.
« Reply #7 on: March 09, 2015, 11:12:28 AM »
something new every day!  ;D
Offline SKTP
« Reply #8 on: March 09, 2015, 11:17:48 AM »
I always thought it was odd I needed a screwdriver for the oil-tank sidecover but not the electrical side...I don't even use the oil sidecover...see you later weird metal inserts!
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline SKTP
« Reply #9 on: March 09, 2015, 11:18:12 AM »
and as always — thank you everyone. What would I do without you
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
