Author Topic: CB550K0 "The Immigrant"  (Read 2320 times)
Offline rodeo
« on: March 09, 2015, 11:08:12 PM »
A while ago I picked up a crusty, but mostly running K0. I say mostly running because the clutch seemed to be stuck. In any case, she wasn't safe for the road at all. After I started looking over the bike at home, I noticed a soggy plastic bag under the seat. Scratch that, soaking wet! Inside the bag I found what was left of the owners manual, and dealer documentation from Japan. It looks like this bike was purchased in Japan and then imported by someone in the military. I thought it was weird that most of the stickers were in Japanese.
I did what I could to save the wet paper. The owners manual is pretty bad, but the Japanese owners manual is mostly there. It has all the first couple service records in it signed by the techs who did them, and a ton of other stuff. I thought that was pretty neat.
I started tearing into this thing almost a year ago, and sort of stopped. Now I've gotten back on the horse... hopefully I remember where most of this stuff goes!
As for the bike, yikes! I've started with worse. I had heart surgery at 26 two months ago, which wasn't too bad, but it leaves me wondering if I'll get back to normal again. My senior year of engineering school is coming to a close as well, so I've just been chipping away at this project slowly. I'm hoping updating this build will help keep me motivated.
So far I have the carbs about 95% rebuilt and polished. Although I may tear them down again to check all the seals between the bodies.
I just checked my bores and pistons. It looks like I'm within wear limits on all four pistons, and my bores are not out of round. (although using the dial was pretty difficult) So they are "round enough". I think I can get away with a good hone and some new rings. I want to get my top end sorted before I split the bottom.
Cleaned and checked my cylinder head and cylinders for warpage. Smallest feeler gauge ( .0015") wouldn't fit. Good there.
Soda blasting, painting and valve lapping are up next.
I will try to get more pics up soon!
I'm trying to decide about powder coating the frame; I feel like loosing a couple of those Japanese stickers would be a shame, but I'm not sure they hold much value other than the coolness factor.
Offline Finnigan
Re: CB550K0 "The Immigrant"
« Reply #1 on: March 09, 2015, 11:59:41 PM »
Pretty cool.  A good powder coat shop can tape off and save any stickers that are metal backed.  If they are just paper they'll burn up in the oven.
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: March 10, 2015, 05:00:19 AM »
That's the speed warning light.  Comes on when you're breaking the law :)
mystic_1
- John Augustus Shedd
Offline rodeo
« Reply #3 on: March 10, 2015, 10:25:02 PM »
Here she is with the tank removed before I pulled the engine. I was unaware about the trick with laying the frame in it's side, so I did it the hard way. The frame has a couple of extra scratches from that unfortunately.
Top end disassembled minus the valve guides. The old gasket was so stuck on there I had to soak it in penetrating oil for a couple days and then attempt to scrape it off. After three days of spending over an hour each day working at it I gave up and took a scotch brite pad and buffing tool to it. Came right off. I was worried I may have taken some material off, but after going over both of the gasket surfaces with my straight edge they look good.
I have oil seals and a new gasket set; as I plan on refreshing all of the seals and gaskets on this engine. My engine set did come with valve stem seals, I think all I'm missing are the black pucks covering the cylinder studs.
Replace cylinder studs yay or nay? They seem to have seen better days.
« Reply #4 on: March 10, 2015, 10:35:31 PM »
Yes, replace with HD APE or Cycle X studs!
Offline mrfish2
  • I might be a
« Reply #5 on: March 11, 2015, 08:37:32 AM »
What kind of buffing tool did you use to get that gasket material off? I'm at the same point in my build and its taking forever.
1976 CB550K            1979 XS1100
1980 CB650C - Sold
It's a little motor and likes having the tits revved off it.
« Reply #6 on: March 11, 2015, 09:50:09 AM »
It's pretty hard to lay the bike over to remove the engine with the front end still on anyway... But removing the breather and oil pan help a lot to get the motor in and out.
While the engine is out, take this opportunity to refresh your carb boots. They will have gotten pretty dried out by now, and a soak in Wintergreen oil brings them back to a nice pliable condition. It makes removal of the carbs easier, but ultimately can resolve vacuum leaks.
Cal,
There are a few different wintergreen oil "cocktails" discussed on various threads (re mixture, temperature and soak time).  Do you have a particular method you like?
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=ken6md4obqd37v95mp4s857l02&/topic,60973.0.html
« Reply #7 on: March 11, 2015, 09:58:27 AM »
if it vas my head..il had go for milling 0,2-0,3milimeter of the surfase. of the head..just as a safty..any car shop or mashinist can do the job .
i hate all this v-w.... vords
« Reply #8 on: March 11, 2015, 10:00:40 AM »
yes, new boots! But I like to spend money  ;)
I buy the new ones, too, but I was wondering if I might try to salvage some crusty 550 boots.
« Reply #9 on: March 11, 2015, 10:44:51 AM »
Yeah, that like baking powdercoat or dishwashing parts, will not be happening in my place -- not if I want any cooked meals.
Offline rodeo
« Reply #10 on: March 11, 2015, 10:18:34 PM »
I just used a scotch brite pad (round) on a polishing air tool. It runs at pretty low RPM.
