Author Topic: Possible carb issue  (Read 1998 times)
Offline Jrb4918
Possible carb issue
« on: March 10, 2015, 08:48:26 PM »
Hey guys, hoping someone might be able to help.  I have a '78 750A, fires right up (with choke), and after warm runs great (no choke).  Then, say 2-3 miles down the road, I lose power.  I've been able to get it home, but noticed that the 1 and 4 cylinders aren't firing.  Spark and compression are fine on each.  Once the bike cools back down, it fires right back up on all 4.  The motor and carbs were completely rebuilt 500 miles ago and it's run since.  I initially was thinking it was the coil, but in that case 1 and4 would never work right?  Appreciate any suggestions.
Offline goldarrow
  • one day, i'll be an
Re: Possible carb issue
« Reply #1 on: March 10, 2015, 09:12:49 PM »
Sounds like classic symptoms of failed dyna ignition.
CB550 K0
Offline calj737
  • I refuse...
« Reply #2 on: March 11, 2015, 06:23:07 AM »
Are you running electronic ignition or stock? If stock, check your condensers and if not that, then swap the coils around and verify the problem moves with the coil. If they're stock coils, test them for resistance and inspect the end caps. Might need a trim on the end wires.
As Goldie said, this is also a commonly reported issue with older Dyna electronic ignitions. (If that's your situation?)
Offline Jrb4918
« Reply #3 on: March 11, 2015, 02:26:20 PM »
It is a Dyna S, was installed when the motor was rebuilt.  Do you think it was defective or is there a fix for it?
Offline calj737
  • I refuse...
« Reply #4 on: March 11, 2015, 02:27:26 PM »
Dyna coils too? If so, swap coils and see if the problem follows. If the unit is defective, you might be able to have it repaired...
Offline Jrb4918
« Reply #5 on: March 11, 2015, 04:57:17 PM »
Has the original coils on it.
Offline Jrb4918
« Reply #6 on: March 24, 2015, 09:18:45 PM »
Right on the money guys.  Installed the new dyna today and she's running like a champ.  Thanks!
