Author Topic: Horsepower Question  (Read 781 times)
Offline mcinturff
  • Less Old-Timer
Horsepower Question
« on: March 11, 2015, 02:00:44 PM »
What would it take to get a 750 up to the same power that a stock KZ1000 makes?
74 CB750
Offline chewbacca5000
  • I polish covers!
Re: Horsepower Question
« Reply #1 on: March 11, 2015, 02:03:35 PM »
Short Answer is about $3 to 5k
Here read this
http://forums.sohc4.net/index.php?topic=98517.0
Offline Powderman
« Reply #2 on: March 11, 2015, 02:06:38 PM »
Take the wheels off the CB and put them on the KZ and you have it.  :)
The CB makes what, 67-68HP?The KZ makes 83-90HP depending on year.
« Reply #3 on: March 11, 2015, 05:43:51 PM »
in realistic, modern day chassis dyno numbers the cb makes between 50-55 and the KZ makes 70-78?...pretty tough to do and still be streetable with a CB
...and expensive too!
« Reply #4 on: March 12, 2015, 04:25:13 AM »
836, ported head and hotter cam made my CB750 to be able to NOT being passed by the Kawasaki 1000 back in 1983-84.
It will cost some when the cam chain needed to be replaced by HD cam chain with opened cases, new primary chains and chain tensioners. While there discover bad bearings, clutch.
Head needed  some guides, valves, HD springs.....
My repair/upgrade back then costed like a NEW Kawasaki 1000J  :(  I'm happy today that I kept my old CB750!  ;D ;)
Who want a 1000J? ???
The last 3 years I have done it again!! I should have known when I started... ::) The total will be same or very close as a new CB11000.
But, I really like my CB750K6, full of memories when I was younger, 18-29.
« Last Edit: March 12, 2015, 04:29:07 AM by PeWe »
« Reply #5 on: March 12, 2015, 06:20:21 AM »
This is an interesting chart showing what these people say is some true horsepower numbers. If you scroll down they list a 1970 CB750 , which should be stronger than other K's, at between 45-48 HP. http://www.factorypro.com/dyno/true1.html
