Author Topic: Wiring ?  (Read 438 times)
Offline turkey4me
  • The closer you are the less you can see!
Wiring ?
« on: March 14, 2015, 05:25:11 PM »
Trying to put all the headlight bucket wiring back together after replacing steering bearing.  Just have a couple questions...
All 3 Brown/White wires coming from gauges and left hand control get connected to the Brown/White wire from the main harness correct?  For some reason in my notes I have written down the Brown/White from left hand control is to black...
Also solid brown wire from main harness doesn't seem to have a home?  Should it???
Offline turkey4me
Re: Wiring ?
« Reply #1 on: March 14, 2015, 06:09:32 PM »
BTW it's a 76 CB750F     I become color blind when I stare inside the headlight bucket for too long...
DH
Re: Wiring ?
« Reply #2 on: March 14, 2015, 07:21:52 PM »
AFAIK all brn/wht wires connect to main harness brn/wht. A black wire (hot with ignition on) is connected with the brn/wht circuits
when the headlight switch is turned to on.  The extra brown is only used for non domestic market bikes that have different
lighting requirements.
« Last Edit: March 14, 2015, 07:25:40 PM by DH »
