Author Topic: RZ350 Kenny Roberts  (Read 18894 times)
Offline rtbmrgl
  • Got Points! Roseville, Ca
Re: RZ350 Kenny Roberts
« Reply #25 on: March 25, 2015, 11:06:55 AM »
I just love the smell of 2-strokes in the morning,  8)
thanks, Mark
Roseville, Ca
Got Points!
1973 CB500 back yard find 1243 orig mi,  http://forums.sohc4.net/index.php?topic=124285.0
1976 CB750 Restoring,        http://forums.sohc4.net/index.php?topic=132997
Offline grcamna2
« Reply #26 on: March 25, 2015, 12:11:26 PM »
Two strokes eat rings faster than 4 strokes so a good peek inside the top end will be a good idea anyways since it already has a problem. How many miles is the odometer showing ?
He mentioned that it had 18,600 showing in a previous post
« Reply #27 on: March 25, 2015, 02:17:39 PM »
Whoops my bad, should have re read.  Worth whatever it takes to make it sing again.
Offline joeyvans
  • Definitely not a
  • God's Country, Earth
« Reply #28 on: March 25, 2015, 09:00:08 PM »
Awesome find, harisuluv! I need to get my hands on one of these before the price gets driven up even more. I'm diggin on the full fairing with the seat cowl and the Toomey expansions. Can't wait to hear it!
1976 CB550 K2
Non-SOHC4 - 1974 CB450 K7
Non-SOHC4 - 1996 VFR750F
"No matter how much you shake and dance... the last three drops go in your pants."
Offline harisuluv
« Reply #29 on: April 03, 2015, 09:10:35 PM »
Here's an update:  Partial fairing removal (I kinda just like it with the bikini), initial "let's see where we're at" wash complete.  Tranny oil drained (looked brand new).
So engine needs to come out to address this whole stuck thing.
Offline harisuluv
« Reply #30 on: April 03, 2015, 09:11:45 PM »
more pics
« Reply #31 on: April 04, 2015, 05:53:31 AM »
Engine look in great shape.  Have you tried rocking it back and forth in 3rd gear trying to free it up?
Offline grcamna2
« Reply #32 on: April 04, 2015, 07:43:20 AM »
AllRight it's up on the rack  ;D ; I hope it'll loosen up easy for you.
Those wheels will shine again if you use a powerful pressure washer to remove that flat black and reveal the oem finish.
Offline harisuluv
« Reply #33 on: April 04, 2015, 07:51:45 AM »
yeah, unfortunately didn't budge :(
Offline grcamna2
« Reply #34 on: April 04, 2015, 07:56:47 AM »
How about removing the cyl. head while it's in the frame to brace it? and using some wood & hammer ? it may have that corrosion from water leakage like you mentioned
Offline harisuluv
« Reply #35 on: April 04, 2015, 08:03:35 AM »
I would be open to that!  I'll try that first.
« Reply #36 on: April 04, 2015, 01:44:05 PM »
Don't beat on the pistons with a block of wood and a BFH: if a piston is at the bottom of the stroke, it can't go any further down, and you can damage the needle bearings in the rod as well as the crank journal. Rig a couple of pullers that bolt to the top of the cylinders with bolts that thread down onto the piston tops (with suitable padding to protect them), and "pull" the cylinders off the pistons.
Offline harisuluv
« Reply #37 on: April 04, 2015, 02:46:27 PM »
thanks scottly!  that is definitely good advice, will take it.
Offline grcamna2
« Reply #38 on: April 04, 2015, 04:09:03 PM »
How do those pistons and cylinders look inside harisuluv ?
Offline harisuluv
« Reply #39 on: April 04, 2015, 06:49:04 PM »
Funny you ask, I just got a glimpse!
« Reply #40 on: April 04, 2015, 06:58:11 PM »
Slugs and jugs look good!?? No evidence of rust or gouges in the cylinder walls from seizing. I wouldn't pull the jugs just yet, without a bit more investigation...
Offline harisuluv
« Reply #41 on: April 04, 2015, 07:32:44 PM »
yeah..  not sure where the next logical place to look would be.  PO said that supposedly the bike had a high speed lock up from a bad shift or something, supposedly though it was "fixed"
« Reply #42 on: April 04, 2015, 07:40:59 PM »
I was wondering about the trans. See if you can get the back wheel to turn backward with the bike in gear. I had a gear tooth break off once, wedging itself between the gears and locking the trans, until I backed the bike up and it fell into the sump.
Offline harisuluv
« Reply #43 on: April 04, 2015, 08:24:20 PM »
I did that when I was trying to "unstick" the top end.  Rocked it back and forth to no avail.  =/
Offline grcamna2
« Reply #44 on: April 05, 2015, 05:07:43 AM »
The stator cover is off,is the 'flywheel' locked-up ? Will it shift at all?
I look forward to what you find  ;)
Offline harisuluv
« Reply #45 on: April 05, 2015, 08:58:28 AM »
Shifts through all the gears. I thought I might just lift the jugs to just verify pistons are free, then read Scott's message and didn't.
Offline grcamna2
« Reply #46 on: April 05, 2015, 09:13:28 AM »
I would pull the jugs just to verify that it isn't the pistons;they sure do look nice from the top though..
« Reply #47 on: April 05, 2015, 01:02:03 PM »
Take a peek through the intake and exhaust ports at the pistons. Also, see if there is any tiny movement of the crank at the flywheel: if a piston is stuck, the crank may be able to move a tiny bit from the clearance in the rod bearings.
This link has pictures and info about engine dis-assembly:
http://www.scooterhelp.com/RZ_help/restorations/engine.start.html
« Reply #48 on: April 05, 2015, 05:48:46 PM »
Can you rotate the rear wheel with the clutch pulled in and the bike in gear? If so, you may want to pull the clutch cover off and check the primary drive gears.
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #49 on: April 05, 2015, 08:22:07 PM »
Yes Scottly, it did rotate like that. So maybe the trouble is all behind the clutch cover. That could be a lot simpler to deal with.
I have a motorcycle problem.
