The SOHC/4 World Tour is in under way.
0 Members and 10 Guests are viewing this topic.
Good news!
Wow!!!! I've never seen a two-stroke get stuck by gas varnish in the crank-case before!!??I wouldn't hot tank the crank. Use whatever solvent James used to clean the carbs, but I wouldn't put the assembly in an ultrasonic cleaner as it may damage the bearings. Are there lubrication passages in the crank? I've never seen them on a two stroke..
Quote from: scottly on April 23, 2015, 06:06:01 pmWow!!!! I've never seen a two-stroke get stuck by gas varnish in the crank-case before!!??+1. Something weird happened, petcock left on and gas filled the crankcase? You should consider rebuilding that crank with new bearings and seals.
That may take some time to flush all that old %*#& out of those bearings,rods,etc.I'd like to know what's good safe stuff to soak'em all in also...you might be able to just clean everything up enough w/o replacing the parts.I believe those holes in the lower case where the bearings ride are for locating dowels for your mains rather than oil holes;that's nice that the engine wasn't seized hard under power but a shame nonetheless having that crap in there.
Quote from: grcamna2 on April 23, 2015, 09:28:29 pmThat may take some time to flush all that old %*#& out of those bearings,rods,etc.I'd like to know what's good safe stuff to soak'em all in also...you might be able to just clean everything up enough w/o replacing the parts.I believe those holes in the lower case where the bearings ride are for locating dowels for your mains rather than oil holes;that's nice that the engine wasn't seized hard under power but a shame nonetheless having that crap in there.I just gave it a little scrub and the worst of the goo in the crankcase is gone, but the crank bearings are still pretty solid. If we can't free them up tomorrow then we may dunk them in Berryman's.
I think you'll have to at least break the crank down and replace the main bearings and seals.
Quote from: grcamna2 on April 24, 2015, 10:37:18 amI think you'll have to at least break the crank down and replace the main bearings and seals.Why?
Quote from: scottly on April 24, 2015, 12:21:28 pmQuote from: grcamna2 on April 24, 2015, 10:37:18 amI think you'll have to at least break the crank down and replace the main bearings and seals.Why?Well,after you get done soaking it in strong solvents the seals may need replacing;I would do it to install the new crank seals and check/scrub down the other parts while it's apart.
never split a crank, so have no idea what it entails, is it something i can do myself? or need a press or something. I've seen rebuild prices for it around 400, but looks like i can get a brand new one for around that
