Author Topic: Electrical Problem!! K3 CB750 Help!!  (Read 706 times)
Offline alanshark
« on: March 15, 2015, 01:41:08 PM »
When I hook my battery up there is current draw coming from somewhere and I don't know where to start looking.  With the ignition switch off, as soon as I connect the terminals the turn signal light and oil light come on.  The tail light also comes lights up.  Any advice or help on where to start would be greatly appreciated!
Re: Electrical Problem!! K3 CB750 Help!!
« Reply #1 on: March 15, 2015, 01:44:37 PM »
I would start at the switch.  Is it stock?
Offline alanshark
« Reply #2 on: March 15, 2015, 01:54:08 PM »
Yeah it's all stock.  By switch do you mean the ignition switch or the run/off switch?
« Last Edit: March 15, 2015, 02:09:01 PM by alanshark »
« Reply #3 on: March 15, 2015, 02:28:55 PM »
Ignition
Offline MoMo
  • Ride like you're invisible
« Reply #4 on: March 15, 2015, 04:41:43 PM »
Agree,  seems like an ignition switch problem.  Does your bike have two separate keys, one for ignition and the other for seat?
Offline alanshark
« Reply #5 on: March 15, 2015, 04:42:48 PM »
Yes it does have two separate keys
Offline MoMo
« Reply #6 on: March 15, 2015, 04:48:45 PM »
Most likely the ignition switch is an aftermarket EMGO-which is not the most reliable thing ever made. I have had one fail almost immediately and others last several years.  ....Larry
Offline calj737
  • I refuse...
« Reply #7 on: March 15, 2015, 05:14:38 PM »
Ignition switch is broken. Can you take a picture of it? It's likely you either have a broken switch, or, you're removing the key with the switch in the ACC position. Some older switches can allow the key to be removed despite being in postion 1 or 2.
Do the lights go off if you rotate the key?
Offline alanshark
« Reply #8 on: March 16, 2015, 05:08:12 PM »
I don't think it's the ignition.  The bike just caught on fire and I had to put t out with a water hose.  I noticed the forks were arcing right around where the tree connects.  Next thing I know the section where all of the electrical components are started smoking and the wires were glowing red hot.  This all happened with the ignition switch off.
« Reply #9 on: March 16, 2015, 05:43:30 PM »
Hmm a fire eh--  That adds a little to the equation  :D   Was going to day there is a parking break feature on the ignition switch but that idea may have been burned to hell   :o
