Author Topic: cam chain tension on 350f  (Read 496 times)
Offline Indy72
« on: March 16, 2015, 02:25:37 PM »
Would I be correct in assuming the cam chain tension adjustment is the same for a 350f as a 750 as given in Hondaman's technique of 15 deg ATF looking at spring post in timing window?
'72 CB350F
Offline ADW
Re: cam chain tension on 350f
« Reply #1 on: March 16, 2015, 02:41:25 PM »
No, here's the cam chain tensioner adjust from the 350F Honda Service Manual (file attached). Make sure your idle is at 1200 rpm or close, most people try to idle these little guys way too slow.
« Last Edit: March 16, 2015, 02:50:53 PM by ADW »
« Reply #2 on: March 16, 2015, 02:46:12 PM »
NO, the 350F cam tensioner is adjusted with the bike running.
Offline Bodi
« Reply #3 on: March 16, 2015, 03:29:21 PM »
Most of the 350 and 400 fours will no longer "self adjust" because the tension springs have lost strength - they've been sitting compressed for decades. Usually they need a bit of help, lots of descriptions here but essentially you remove the cap bolt above the tensioner lock bolt and push down inside from above with something thin, a longish 1/8" blade flat screwdriver works or use a nail. Follow the manual instructions, but press down with increasing pressure until the chain rattle JUST disappears, then tighten the clamp bolt (not too tight, they love to break off) and its lock nut. Done. Over tensioning past where it quiets will cause increased friction and rapid wear of the tensioner blades. Replace the cap bolt
The springs etc are captive and don't come out of the cap bolt hole. No oil will squirt out. No drama at all, just a quiet engine afterwards.
This risks severe hand and arm burns from the very hot headers: be super careful!
