Author Topic: Leaky neutral switch- 550  (Read 572 times)
Offline tfrasca
    • CB550 Project
« on: March 16, 2015, 04:21:07 PM »
Why am I having such a hard time finding a replacement seal for the neutral light switch on my '76 550? Surely this part is still available?
I've seen posts that refer to an o-ring that seals the switch, but mine sure looks like a seal (similar but not identical to the shift shaft seal). Can anyone point me in the right direction?
Thanks so much,
TF
Offline tfrasca
    • CB550 Project
Re: Leaky neutral switch- 550
« Reply #1 on: March 16, 2015, 04:30:22 PM »
Just to clarify, the seal in question is the upper one in this picture.
Offline DaveBarbier
« Reply #4 on: March 16, 2015, 05:05:24 PM »
Also, do you have an o-ring chain? I see some wear on one of your seals.
1978 Honda CB550K
Offline tfrasca
    • CB550 Project
« Reply #5 on: March 16, 2015, 05:13:45 PM »
Thanks so much, Dave.
I ordered some seals just now. I was calling it a neutral switch seal instead of shifter drum seal.
The PO must have had an O-ring chain on it, because that wear was there when I got it. It had a standard chain on it when I got it, and I just replaced the chain and sprockets with a new standard roller chain, and no issues so far.
Thanks again!
TF
Offline DaveBarbier
« Reply #6 on: March 16, 2015, 05:31:41 PM »
Cool, no problem. I had chain wear from a PO using an oring chain too. My seal was worn much worse than yours. Now when I see it on someone else's bike I have to make them aware.
1978 Honda CB550K
