Author Topic: Cb 550 four bigbore Engine  (Read 1550 times)
Offline ApriliaRacing
« on: March 20, 2015, 12:57:51 PM »
Hi guys
I will Build a bigbore Engine.
It is based on a 500 motor with a 550 cylinder. I wanted the bigbore Kit from Japan but this is no longer really in ebay. 2 more are now in it but slightly more expensive. someone that has made experience or can say something or help me which I should take?
http://pages.ebay.com/link/?nav=item.view&alt=web&id=231405679652
http://pages.ebay.com/link/?nav=item.view&alt=web&id=141467656109
and what compression drive you where bigbore kit? What for Camshafts and carburetor ride her?
I'll still install an electronic ignition. you have experience with the replika yoshimura exhaust system or which ride you so? very loud is the yoshimura? I hope that I can go and not to bad is striking in Germany?
the cylinder head is ausgelitert and the channels are smooth and easily advanced.
What would you recommend her yet or what have you done otherwise still?
Offline dusterdude
Re: Cb 550 four bigbore Engine
« Reply #1 on: March 20, 2015, 03:39:17 PM »
What is sufges?
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: March 20, 2015, 03:52:29 PM »
Suggest?
« Reply #3 on: March 20, 2015, 04:20:48 PM »
I have the Japanese 600cc kit Pistons if you need them. http://forums.sohc4.net/index.php/topic,146017.0.html
« Reply #4 on: March 21, 2015, 06:22:10 AM »
In june Is the kit from Japan available. But Is this the best or give it no Information to the other two kits?
With compression do you Drive by the Japan piston? One of the other kits had 9,8:1 and the other 9:1 i think the Japan had also 9:1. Is this the best oder a Little bit more?
What do you want for the kit? Why do you sell it?
