Author Topic: Front Sprocket Torque F2 SOHC  (Read 395 times)
Offline ajduke5
« on: March 21, 2015, 08:06:46 AM »
Hi.
I have an F2 SOHC and can't for the life of me find the torque for the centre bolt that holds the front drive sprocket on. It only has the one bolt that goes into the spline, not the two bolt type. I found some mention of 5 kg.m but seems a little high. Last thing I want to do is strip the thread in the spline.
Cheers
Aaron
Re: Front Sprocket Torque F2 SOHC
« Reply #1 on: March 21, 2015, 08:21:38 AM »
4.5-5.5kg is correct. shop manual Pg 245  suppliment to 750f pg 22
I'd also use some red locktite
« Last Edit: March 21, 2015, 08:23:22 AM by flybox1 »
Offline Airborne 82nd
« Reply #2 on: March 21, 2015, 08:27:48 AM »
Hi.
Cheers
Aaron
Look at the service manual  the supplement page 261.
32.5-39.8 lbs-ft. This is for a 750
Offline ajduke5
« Reply #3 on: March 21, 2015, 08:28:58 AM »
Thank you. A little reassurance is always a help. I did read that loctite was a good idea. I'll put some 2700 on and torque it up.
