Author Topic: Quick - what's the trick for round gaskets in pentagonal float bowl grooves?  (Read 875 times)
Offline Jayelwin
So I have round gaskets (should've bought the shaped ones) and I can't prevent them from slipping out of the groove and then getting pinched. Does anyone have a trick to temporarily securing them in the pentagonal float bowl groove so you can put the float bowls back on?
Offline greenjeans
  • 1972 CB750K2
tiny dabs of superlue
You can use a glue stick or even nail polish to hold them in place.
Offline Jayelwin
Trying that $0.25 tube of superglue gel from HF.
Offline Mr Freeze
I've also used gasket maker in little dabs just like the superglue with success. The only problem I've had with superglue is that it makes the rubber hard and it lost it's ability to seal the bowl and I got a leak.
Offline Jayelwin
I was wondering about what superglue would do to the gasket. I used very little. The glue worked great - the gaskets are well seated and the bowls are on. Too cold to mount the carbs on the bike today though.
Did you buy the o rngs with proper size, or did you measure them?
« Last Edit: March 21, 2015, 04:44:08 PM by 754 »
I have used all of the above plus bearing grease
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=v9pd56qmff5lr00kketojt55d4&/topic,60973.0.html
have any tryed the paper gaskets as alternative..the are sold on e bay..vas looking for cbx 1000 kaburetors kit..but did go for the standart type..hate to pull 6 kabs if it not did vork
i hate all this v-w.... vords
Offline jmelche2
  • 1974 CB750K
I use a piece of Scotch tape on each side.  Once the bowl is seated in place, gently remove the tape, then snug down the bowl.
Offline wowbagger
  • Not much of an
I went with a dab of heavy grease. The fuel will dissolve it and it causes no damage to the o-ring. The next guy to replace them will thank you for not using something more permanent.
Offline FunJimmy
  • Who you calling
  • Vancouver
Hylomar!
Offline BCBarker
  • Hey
Heavy grease or a little white glue in the corners and you're good to go.
