Author Topic: Building my own turbo kit  (Read 9539 times)
Re: Building my own turbo kit
« Reply #25 on: August 07, 2015, 02:51:39 PM »
You have some seriously. Nice parts there.. Did you find the Morris mags over there?
http://forums.sohc4.net/index.php/topic,148592.0.html
Offline hotdog
« Reply #26 on: August 25, 2015, 05:03:23 AM »
Quick update -
Full Rajay b25 rebuild kit from Terry Kizer @ MrTurbo
Had the lube Tech's at work make these up for me.
Later
Instagram - Lumpy Cam Motorcycles
FB - Lumpy Cam Motorcycles
Instagram - LUMPY CAM MOTORCYCLES
FB - LUMPY CAM Motorcycles
Offline turbocity tom
« Reply #27 on: August 26, 2015, 12:02:30 PM »
Hi,  my first post here,
don't be afraid of the draw thru system.  this is one on my 79 DOHC 750 (sorry) but would set up the same for your application.
I have put about 1K miles on this and runs great- built as a driver, not racer. limited to 7 psi- pulls like a 1400cc bike.
Let me know if you have any questions, i'd be glad to help.
Thanks  Tom
PS,  I have a 72 cb500/4 project that i am just finishing- will post a build thread on it ( 605cc/ ported/ 650 cam/ pd50b carbs)
« Reply #28 on: August 26, 2015, 12:29:47 PM »
Can you put a pic on ofthefront? Want to see the pipe work. Did you build it out of mandrel pieces?
« Reply #29 on: August 26, 2015, 01:04:59 PM »
Hi,  here are couple of pictures
Here is a picture of the bike finished.
All the parts are custom built by myself. the header is from mandel bent U bends
Sorry, i do not want to HiJack the OP's thread, but feel I can help with this
Thanks   Tom
Offline hotdog
« Reply #30 on: August 26, 2015, 03:20:08 PM »
Tom any input appreciated.... this is after all about me building a kit from a selection of parts...hopefully making the process easier for anyone that wants do do the same.
Nice looking dohc - I used to have a 1980 900f - another one I should've kept.
« Reply #31 on: August 26, 2015, 04:00:31 PM »
Let me know if you have any questions- I have 30+ years in the turbo field
I have a build thread of my bike on the DOHC site.  don't know if it is OK to link it here, but can send you the link thru PM if you like.
Thanks   Tom
« Reply #32 on: August 26, 2015, 04:07:45 PM »
Thanks   Tom
Hi Tom and welcome. We have an "other bikes" section, you could copy and paste the whole thread in there if you like... ;)
http://forums.sohc4.net/index.php/board,10.0.html
Offline hotdog
« Reply #33 on: August 26, 2015, 09:56:46 PM »
Thanks   Tom
A link would be great either post it here as suggested or p.m.
Offline hotdog
« Reply #34 on: August 28, 2015, 09:34:49 PM »
A question for the viewers...
Just been reading about methanol injection and some of the systems used, when the mix is feed to the carb from the header tank under boost how is the mixture fed to the carb.?
Reason I ask is back in the day we used to fit powerjets to the o.e.m. Evo cv harley carbs and some s&s carbs that were fed directly from the float bowl. Question is -is the methanol mix fed through a similar jet..? Obviously there are the 2x 5lb one way valves to regulate delivery....just wondering about delivery to the carb.
« Last Edit: August 29, 2015, 03:16:25 PM by hotdog »
Offline hotdog
« Reply #35 on: August 29, 2015, 04:53:07 PM »
Found some good info on building your own kit -
http://www.turbomirage.com/water.html
Offline hotdog
« Reply #36 on: September 09, 2015, 08:47:01 PM »
Since the MrTurbo rebuild kit had arrived a while back I'd thought I'd rebuild the B25 today
After protecting the shaft surface I ran the turbine wheel through the bead blaster to remove all the carbon build-up.
Assembling - checking shaft end plays...
Definetely a B25
And assembled after shimming the compressor wheel to set end play.
Need to make a manifold to join these two together - it's never ending....
Later
« Last Edit: September 09, 2015, 08:52:28 PM by hotdog »
« Reply #37 on: September 10, 2015, 01:15:48 AM »
Nice work mate... ;)
Offline hotdog
« Reply #38 on: December 11, 2015, 03:27:12 PM »
Latest acquisition for this project, cbr1100xx roller I got for a good price.
Can anyone tell me the difference between output shafts over the years, with pictures..?
I'm sure I've read somewhere that the later shafts have a longer spline to mount the sprocket..? I'm gonna need all I can get, plus probably an offset sprocket.
Sent from my HTC_M9u using Tapatalk
« Reply #39 on: December 11, 2015, 03:41:11 PM »
Good morning Dale, the F2/3 and K8 had a 10mm longer output shaft, not too sure how easily they fit into earlier cases, different bearings. You sticking the turbo on the 1100...?
Offline hotdog
« Reply #40 on: December 11, 2015, 03:48:34 PM »
Good Morning, 1100xx front and rear ends to be swapped onto the ko frame with the 970 draw thru turbo....one-day...
similar to Ilja's turbo project.
Gathering parts slowly... Thanks for the info about the shafts, I'll have a look at my parts stash.
« Reply #41 on: December 11, 2015, 03:53:37 PM »
Ahhh, that makes sense, for a minute there i thought you were building missile... ;D ;)
