Author Topic: 3 questions about cb750 engine...  (Read 1278 times)
Offline la ca fe
« on: March 22, 2015, 09:12:38 AM »
I have questions about 1978f motor:
Engine is stuck, what is the best lubricant I can put in the cylinders to unlock it?
Could I use a 74 cb750 head and jugs on a '77f motor?
Is there a good way to estimate it's mileage?
Thanks a lot.
1976 cb750k
1975 cb750 f
1977 xs750
1978 xs400
Re: 3 questions about cb750 engine...
« Reply #1 on: March 22, 2015, 10:09:30 AM »
I used a 50/50 cocktail mix of Acetone/ATF to "unstuck" my K7. Let it soak for a day or two and then rock it in 3rd gear (if motor is still in frame).
Yes.
Not that I know of.
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: March 22, 2015, 11:28:59 AM »
Only if you use the early (flat top) pistons too.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline brandEn
« Reply #3 on: March 22, 2015, 11:49:37 AM »
pro tip-
use the 50/50 mix of acetone and trans fluid but make sure to cover the engine with a towel or rag. When that motor breaks free all the fluid that's in the cylinder will SHOOT out the plug holes and make a mess out of the ceiling and everything 20 feet away.
Offline Johnie
« Reply #4 on: March 22, 2015, 12:36:17 PM »
And how would you know that Branden :)  Good tip!
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
« Reply #5 on: March 22, 2015, 01:27:47 PM »
pro tip-
Hey brandEn......I have the record, it is 17 feet!
Offline la ca fe
« Reply #6 on: March 22, 2015, 02:41:05 PM »
Thanks for the tips. I will give the 50/50 mixture a try.
1976 cb750k
1975 cb750 f
1977 xs750
1978 xs400
Offline brandEn
« Reply #7 on: March 22, 2015, 04:38:50 PM »
Yup I learned that one the hard way! Good thing my car was not in the driveway or it might have ruined the paint.
Offline calj737
  • I refuse...
« Reply #8 on: March 22, 2015, 05:24:25 PM »
I'm a big fan of the 50/50 mix too, but if that doesn't work, try a vinegar soak. It eats the rust lickety-split. You absolutely do need to drain the motor and replace with some oil once it breaks free though. Even if tearing down...
