How's it going everybody!
There is a lot of great information on these forums and I am glad to be apart of this site as of now! I recently got into the cafe racer scene as I really like the overall style and heritage of the older jap bikes.
I picked up a 1973 CB750 in December that has had some work done to it by the previous owner. It has a custom rear seat, the frame was done in an interesting way in order to cover up the previous oil tank brackets..custom front headlights, forks apparently off a suzuki.
Also: new points, new spark plugs and wires, new ignition coils, new gaskets on the interior, valves had been gapped (lashed), fully rewired, stainless breakline, rebuilt front master cylinder and front break, new dunlop tires, new spedometer. He said he rebuilt the engine but I don't believe anything serious was done other than replaced gaskets.
This is how I bough the bike from the owner for 2500.00 off kijiji.
16733486610_1d68a7885e_o by
fpi_tactics, on Flickr
Decent looking bike. I drove it around, it was pretty damn cold around -20 but me an my buddies were excited to get it off the trailer and start it up. The bike started up without any problems when I went to go see the bike. It did so again however died a couple times (because of the cold I guess) and after warming up it did seem to bog a bit in the higher rpms. Anyway warmed up the bike again the next week and took it for a spin, no bogging this time worked pretty good had a healthy idle (a little backfiring).
*First problem, the custom rearsets were attached to some piece of aluminum and the welded onto the frame, these flew off while riding (I guess after using the kick start a couple times. The rearsets did not have enough clearance and interfered with the kick start).
DSC_0229 by
Second problem, I noticed quite a bit of oil or unburned gas in the left tailpipe (its a 4-2 exhaust) after warming it up the second time for about 20 minutes. I had pulled off the exhaust (to repaint) and removed the spark plugs. Looks like its coming from cylinder 1 (if im not getting it backwards). Plugs also seem to be fouled, so it's running a bit rich I assume.
Here you can see the unburned fuel or oil
DSC_0024 by
There was about triple this amount in the exhaust tip
DSC_0026 by
The inside of the corresponding headers
DSC_0053 by
DSC_0052 by
Here are the spark plugs, the plug from the leaky cylinder is black and a bit wet as you can tell by the first photo. All of the other plugs are sort of dusty black, (second photo)
DSC_0039 by
DSC_0038 by
Anyway they're Champions so first thing I did was buy Some NGKS's. Will be gapping and installing them soon. Anyone know what the gap is on these??
DSC_0071 by
I also bought some new pod filters (old square breadbox filter) for the carbs which seem to be in decent shape. Im going to have them cleaned, and also replacing all the fuel lines and filters (i broke one as you can see)
DSC_0054 by
DSC_0065 by
DSC_0029 by
DSC_0075 by
Also got rid of these chrome grips and bought something nicer
DSC_0068 by
DSC_0083 by
Anyways, in order to address the first problem I started off by buying these custom CNC'D rearset brackets from CognitoMoto.
Very happy with the part, although it was a bit expensive to ship, especially with the Canadian dollar being so low (not the best time to be buying stuff from the states on a regular basis) I had some friends help me out grinding down and cleaning up the old tig welding marks. I have a airbrush coming in the mail so I will paint over that nicely as well.
DSC_0019 by
DSC_0021 by
These are the custom cb750 rearsets from CognitoMoto, and some photos of the workspace
Also bought some plastidip as I plan on painting the bike flat black! and still retain the copper orange paintjob for the future
DSC_0093 by
DSC_0078 by
DSC_0082 by
DSC_0070 by
DSC_0055 by
DSC_0076 by
ALSO, I decided to take off the tank as there was a bit of rust inside. After 2 days of it being taken off the bike, and filled with 18LITERS of APPLE CIDER VINIGAR, it was completely spotless. Magic. I didn't put bolts and washers in or or anything, I just let it sit for a couple days. The rust came back kind of quickly at the cap, but I shall clean it again quickly after painting it and fill it with gasoline. Also bought a new rear mounted licence plate bracket off of ebay for 40.00, which included the break light.
Guess what, the petcock was also cracked when I took it out so I'm getting a new one along with some other miscellaneous from vintage0cb750.
DSC_0098 by
DSC_0016 by
DSC_0088 by
Probably my biggest worry/ problem with the bike right now is at the fork and headtube. Looks like it was hacked at with a flathead in order for the fork to properly clear.
I dont think its a big issue although Im not quite sure about this. It does however not look too great. Probably the worst part about the bike I think.
DSC_0056 by
DSC_0060 by
More to come!! Thanks for reading! If you guys have any advice in regards to the Oil please let me know! It could be the piston rings however I dont want to pull the engine out just yet, as Im thinking of selling the bike.
I am going to put in the new park plugs, get the carbs cleaned, get the thing tuned and ignition coils timed, install other parts I have ordered (mechanical and aesthetic) and take her around for a couple rides as the weather here is finally starting to warm up. And Ill be taking it from there!
