Author Topic: CB550 valve cover on CB650 cylinder head  (Read 1682 times)
Offline reverb
« on: March 25, 2015, 01:50:00 AM »
I am customizing a CB650 from 1982.
I'm looking for the power from the 650 engine combined with the good looks from the 500/550   ;)
I can get an engine from 1979 with the smooth flange on the head where the valve cover rest.
Will it be a close fit or will it be necessary to thicken the head casting to make a wide enough surface for a good seal ?
Will the 550 rockers be a one on one match with the 650 rockers ?
Are there other problems to deal with ?
Re: CB550 valve cover on CB650 cylinder head
« Reply #1 on: March 25, 2015, 04:57:53 AM »
550/650 rockers will interchange. They may not be identical looking as the 650 uses a spring on one side of the rocker, but ratio is the same. I believe the 650 head needs some welding in spots to allow a 550 cover to seal. You're not the first so maybe search around here for better info on the head and cover.
« Reply #2 on: March 25, 2015, 09:43:03 AM »
Unless retaining a kick start is a requirement, you may simply transplant the entire 650 motor into the 500/550 frame.  The only glitch is that you will need to remove the valve covers, oil pan and filter before installing the motor.
Offline reverb
« Reply #3 on: March 25, 2015, 11:30:58 PM »
Thanks bwaller,
So if I understand it well you can change the valve covers but keep the rockers from the 650.
it is good to hear that it can be done.
« Reply #4 on: March 26, 2015, 04:31:53 AM »
Thanks bwaller,
Yes....but not without some work.
Here's a link to someone who made it work. Beautiful job too.
http://forums.sohc4.net/index.php/topic,63938.0.html
Offline turboguzzi
« Reply #5 on: March 26, 2015, 02:46:29 PM »
yes, seen at least two, seemingly with the up to 80' head (better flow), so doable
your best bet is getting a cheap one from ebay and see where's the welding needed
