Author Topic: Brat - CeeBee-6-Fiddy - Never Done  (Read 12578 times)
Offline WnRn
    • my WnRn blog
« on: March 28, 2015, 12:52:50 AM »
The Brat has emerged...
Big shout out to Liam Butler of Butler's Customs and Race Racers for making the seat. My bike had been with him all week. He is a true garage artist. A true gentleman. He builds sweet rides.
I did not want major chopping done to the frame. So the rear frame loop/hump stayed.
Most cut this off.
The seat mounting brackets have been removed. A new seat base crafted.
That huge tail light is coming off. It looks like the docking bay of the USS Enterprise from Star Trek.
« Last Edit: June 08, 2015, 02:54:24 AM by WnRn »
I come from the land down under...
The chief enemy of creativity is common sense (Pablo Picasso)
Offline WnRn
    • my WnRn blog
Re: Brat - CeeBee-6-Fiddy
« Reply #1 on: March 28, 2015, 12:55:51 AM »
Today tail end has been attacked.
The rear guard fought me the whole way. I drilled a hole in it and the chrome flaked off. I ended using the CL450 rear guard I had lying around. It was trimmed down to remove a rust patch.
Offline WnRn
    • my WnRn blog
« Reply #2 on: March 28, 2015, 12:57:53 AM »
Making sidecovers. They will be black.
« Reply #3 on: March 28, 2015, 12:11:08 PM »
You will want to weld in a new cross-member where you cut out what you call the "hump."  That cross-member provides structural rigidity to the rear top of the frame to prevent twist.
Offline koendd
« Reply #4 on: March 28, 2015, 02:04:45 PM »
fortunately he didn't cut it off  ;)
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
Offline WnRn
    • my WnRn blog
« Reply #5 on: March 29, 2015, 01:55:43 AM »
Yep the hump stayed for this very reason.
« Reply #6 on: March 29, 2015, 07:40:53 AM »
My mistake.  It looked like it had been cut off in one of the later pictures.
Offline WnRn
    • my WnRn blog
« Reply #7 on: March 29, 2015, 11:08:57 AM »
Thats exactly what we wanted when we designed the seat. To hide that hump and make it look like it had been chopped.
Offline WnRn
    • my WnRn blog
« Reply #8 on: April 02, 2015, 11:16:57 AM »
Some better photos. Still working on the perforated side-covers. Day job gets in the way.
Offline CBJoe
« Reply #9 on: April 03, 2015, 04:46:40 AM »
Looks good!  Do you happen to have a sound clip of the Marshal Pipe?
'07 Bonneville Black
'65 CB77
'66 CM91 (C90'ish)
« Reply #10 on: April 03, 2015, 11:50:43 AM »
Your bike is a 1979, correct?
Offline WnRn
    • my WnRn blog
« Reply #11 on: April 03, 2015, 02:00:49 PM »
Offline WnRn
    • my WnRn blog
« Reply #12 on: April 04, 2015, 03:26:22 AM »
Attacked the front end today.
Different headlight ears. So I can lower the headlight. Which should change the lines of the bike.
Got rid of the tacho. Made an idiot light console from a mirror.
Two goes at wiring these lights in. They have such fine wires that they break so easy. I have neutral light. OIl light comes on and stays on. I think the oil light is earthing twice. No I do not have an oil pressure problem. That will do till tomorrow.
Offline WnRn
    • my WnRn blog
« Reply #13 on: April 04, 2015, 08:26:49 PM »
Finished lowering the headlight.
Now only have Speedo. Lowered it too.
Made idiot light console.
Cleaned from brakes and new brake fluid.
Fitted black rectangle bar end mirrors.
Still have to make the side-covers.
Offline Bootsey
« Reply #14 on: April 04, 2015, 11:36:39 PM »
Looking good - the headlight shift makes a difference, so does having that Honda badge off the lower tree.
What else is on the cards for mods?
Offline scunny
  • don't call me expert
« Reply #15 on: April 05, 2015, 12:11:11 AM »
If you want to clean up the front end some more, ditch the fuse holder on the top triple tree and replace with blade fuses down by the battery.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline WnRn
    • my WnRn blog
« Reply #16 on: April 05, 2015, 12:21:09 AM »
Cheers guys. Glad you like what I have done so far.
I still have to finish off making the perforated sheet side-covers.
I had thought of moving the fuse block down around the seat area.
I may get a mini speedo with built in idiot lights and ditch the speedo that's on it at the moment.
I need to find a four into one collector as I want/need to replace the muffler. The baffle instead has come loose and is rattling around. Plus there is this horrible repair that was done to the muffler. Looks like it was welded up then chromes. Now the weld is breaking up and the chrome is splitting away.
The muffler I would like is a Dan Moto as fitted like this photo..
Offline WnRn
    • my WnRn blog
« Reply #17 on: April 05, 2015, 02:36:30 AM »
Offline Ichiban 4
  • "Ichi"
« Reply #18 on: April 05, 2015, 05:16:31 PM »
Really good to see stuff on the 650's here.  Last of the SOHC 4 series..but seems decidedly under reported or covered (great looking bike too!)
Thanks WnRn..
Ichi
Al Summers
Present: '77 550K
Offline WnRn
    • my WnRn blog
« Reply #19 on: April 05, 2015, 09:16:57 PM »
Some general shots I took today..
« Last Edit: April 06, 2015, 04:20:40 AM by WnRn »
Offline koendd
« Reply #20 on: April 06, 2015, 06:52:18 AM »
lookin good!
I'd shorten the rear fender if I were you and ditch those engine bars ;)
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
« Reply #21 on: April 06, 2015, 07:41:03 AM »
Looking good. I would Echo Bootsey and koendd's suggestions.
Offline WnRn
    • my WnRn blog
« Reply #22 on: April 06, 2015, 12:35:55 PM »
lookin good!
Engine bars for sure are coming off. They will be replaced with some crash knobs made from skate board wheels.
The rear guard is as short as I can legally go without the authorities defecting the bike and forcing it off the road. Plus a defect notice costs money.
« Reply #23 on: April 06, 2015, 01:05:14 PM »
lookin good!
Installing frame sliders is not a bad idea.  However, I don't think that skateboard wheels have the same abrasion resistance of Delrin or sliders with more robust material.  Remember that you want something that can support the force of a 220 kg (485 lb) motorcycle plus its inertia.  I don't think a skateboard will hold up to that abuse.  It will likely tear apart and defeat the purpose.
Offline koendd
« Reply #24 on: April 08, 2015, 01:08:16 AM »
oh, didn't know there were regulations for the length of a mud guard :)
to bad!
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
