Author Topic: Can't shift out of neutral - CB750  (Read 663 times)
Offline onetruepunk87
« on: March 29, 2015, 05:41:15 PM »
I spent all weekend doing pre-riding season maintenance on my '77 CB750k; changed to stainless brake lines, new front and rear brake pads, new sprockets and chain, charged battery... After getting everything back together I went to start it up since it sat all winter. Bike started fine, I let it idle and warm up a few minutes. I went to shift into first gear and NOTHNG. The shift lever moves like it wants to shift gears but nothing's happening.
The bike has sat since mid November but prior to that I had put 3000+ miles on it over the past two years. Could the clutch plates be stuck from sitting and the cold temperature? I haven't messed with the clutch at all since I parked it and I don't think I touched anything putting the transmission cover back on after changing the chain and sprockets. Bike was shifting fine when I put it in the garage for the winter. I plan on changing the oil later this week when my new filter comes in the mail. Besides fresh oil and some longer time warming up are there any suggestions on unsticking the clutch?
« Last Edit: March 29, 2015, 05:43:30 PM by onetruepunk87 »
Re: Can't shift out of neutral - CB750
« Reply #1 on: April 04, 2015, 03:31:40 AM »
Usually when not running a cb750 can still be shifted into gear without using the clutch by rocking it back and forth while toggling the shifter up or down.
   I have had bikes that have set for extended period where the plates get stuck and usually a good warm up with some hot oil helps break them loose as well as rocking in gear while off. Tying the clutch lever back for an extended period helps also.
   Keep trying to see if you can at least get it in gear.
« Reply #2 on: April 10, 2015, 10:53:16 AM »
Update: I'm an idiot. The shift arm, where it connects to the transmission, came disconnected when I took the transmission cover off. I didn't notice it was out when I put the cover back on. When I went to shift the pedal moved but it wasn't connected to anything.
