Author Topic: cases polished dang !  (Read 3645 times)
Offline jeepurz
« on: October 14, 2006, 04:53:00 PM »
got my cases back from a buddy for the cm project bike, theres an oil filter cover beside them to use as a referance as to how mucked up they were,  dang this cat did one hell of a job.now Ive got the incentive to start puttin motor back .
Offline Bob Wessner
  • "Carbs Suck!"
Re: cases polished dang !
« Reply #1 on: October 14, 2006, 04:56:33 PM »
Very nice! What's the plan to keep them that way. ???
Offline 78 k550
« Reply #2 on: October 14, 2006, 06:13:42 PM »
wow, those are nice.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline jeepurz
« Reply #3 on: October 14, 2006, 06:30:41 PM »
the last ones I clearcoated, nothing fancy just clicky can clearcoat.  Id like to watch this done once just to see how they get them this nice.
Offline kghost
« Reply #4 on: October 14, 2006, 06:56:33 PM »
Looking Gooooooood  ;D
Like them comstars btw....always were my favorite ones
Stranger in a strange land
Offline DiscoEd
  • Keeping it surreal!
    • My personal gallery is at:
« Reply #5 on: October 14, 2006, 07:05:49 PM »
Excellent!
Hey, if the guy is a "buddy", then shouldn't a few beers loosen his lips?
(P.S. Don't forget to report back all of your findings here!)
Regards,
DiscoEd
1975 CB550 K1
1976 CB550
1974 CB360
2003 Suzuki Volusia Intruder
http://gallery.sohc4.net/main.php?g2_itemId=1954
Offline jeepurz
« Reply #6 on: October 15, 2006, 06:26:15 AM »
Excellent!
Regards,
DiscoEd
hmmmmm maybe I could install a secret web cam.
Offline Namba1032
« Reply #7 on: October 15, 2006, 10:39:04 AM »
Its not that hard to get stuff looking that good, just go to your local hardware store and pick up a couple of buffing wheels.
Get the ones that are stitched very tight all the way around the wheel. In other words, a rugged one that isnt all flabby. Also pick up a flabby one to get into the hard to get crevices. ( I got mine at home depot)
Get a set of polishes that are in a wax stick form to apply to the wheels. Oddly enough, as cheap as Ryobi stuff usually is, their buffing wheel polish works Very Well. I got some from a couple other places that didnt compare, but this could have been due to the fact they were sitting on the shelf for so long.They have a bunch of differnt compounds for different materials. You only need enough so you can see it on the wheel, dont try to push hard on it to get "a lot" on the wheel, because the majority of it will go on the floor instead, so push easily until you see it build up on the wheel.
Sit down and get your stuff shiny! This will rip the oxidation off and depending on how much time you put in, will determine how good it looks.
After everything looks as good as you can get it with the Ryobi stuff. Take a towel and apply some Mothers Mag polish to the wheel (not to much cause it will fly off the wheel a little) then polish your parts quick with that and your stuff will be like a mirror.
Another tip: WEAR A MASK, the wheels will progressively desinigrate leaving behind lots of fabric dust thats sticky with polish. And you'll be breathing this crap in and coughing it up for a good while if you dont wear a mask.
This is how my stuff came out:
Offline Namba1032
« Reply #8 on: October 15, 2006, 10:41:27 AM »
This old peice of junk is what I used
Offline crazypj
  • I'm brill, me
« Reply #9 on: October 16, 2006, 08:33:33 AM »
Thats a really nice job.
 Impressed with the clutch cover as its pretty difficult not to get ripples in something that wide. (probably easy for a professional)
PJ
Offline jeepurz
« Reply #10 on: October 16, 2006, 11:41:21 AM »
PJ
pj I may have to get with ya on the cm got motor split and thats way more complicated then the xs was decided to split it rather than risk splitting the timing chain. Its a lot harder to find tips on these bikes . better yet you could slide up here do some ice fishing .them fla winters make ya soft.
Offline Namba1032
« Reply #11 on: October 16, 2006, 07:13:02 PM »
Thanks for the compliment, took me a while to get those parts looking like that but I was happy with the way it came out. Your right about the clutch cover though. That was probably the toughest peice to get like that, the rippling really wasnt the problem, just the fact that it had a few tight areas on the bottom and so forth... But enough about me, jeepurz looks like hes on his way to making a pretty sweet ride. You'll have to keep us posted!
Have a good one
Brian
Offline jeepurz
« Reply #12 on: October 17, 2006, 12:01:08 PM »
Have a good one
Brian
you ever buy anything from casewells?  this place has it all.   http://www.caswellplating.com/buffs/buffman.htm
« Reply #13 on: October 17, 2006, 12:35:58 PM »
PJ
This was a very good job. It is very easy to avoid ripples. When cutting with heavy rouge keep moving back and forth. For the final polish use a buffing bonnet. This alloy is pretty hard and forgiving.
