Author Topic: Alternator still good?  (Read 989 times)
Offline AlekStooge
  • can't afford cheap stuff
« on: March 30, 2015, 04:43:46 PM »
Can anyone comment on the condition of this alternator? Is it worth saving? Should I get a new one? The bike has a problem staying charged. Already have a new rec/reg and battery.
This tan powder came out when I opened it.
Offline calj737
  • I refuse...
Re: Alternator still good?
« Reply #1 on: March 30, 2015, 05:50:25 PM »
You can test the stator for proper charging output. If you do need to repair it, Rick's sells rebuilt units of good quality.
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: March 30, 2015, 06:00:11 PM »
We'll need better pictures of the coils, that first one is too blurry to tell if your "tan powder" is the insulating lacquer flaking off of the stator windings.   If so you will need a replacement.
Test for continuity between the three yellow leads at the plastic connector.  You should get 0.2 ohms resistance between any two yellow wires.
mystic_1
- John Augustus Shedd
Offline Airborne 82nd
« Reply #3 on: March 30, 2015, 07:00:46 PM »
Do you have a link for Rick's
« Reply #4 on: March 30, 2015, 07:13:05 PM »
Too many other likely culprits. Lets see what your resistance test comes back as. This is a simple device.
Offline calj737
  • I refuse...
« Reply #5 on: March 31, 2015, 04:26:11 AM »
http://ricksmotorsportelectrics.com/aftermarket-stators
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=bioofji9er6ocb32b50a2g0gq3&/topic,60973.0.html
« Reply #6 on: March 31, 2015, 04:53:29 AM »
any elektro vinding shop can make the stator vith nev vindings...ve doing it often at langelands elektro in denmark..but bay a used on e bay..they are mostly not defekt...so go to a shop and get it thekked..it are prob ok..
but thek the komponents.. dont just thange parts..its to expensive...
« Last Edit: March 31, 2015, 07:36:37 AM by strynboen »
i hate all this v-w.... vords
Offline Bodi
« Reply #7 on: April 01, 2015, 08:22:47 AM »
Unless you love spending money on stuff you don't need, test the coil first. The yellow wires should have the same resistance between all pairs and no connection (infinite ohms) to the case. The actual resistance spec is in the shop manual - remember most meters are inaccurate at low Ohms, a reading close to spec and equal across the 3 measurements is what you want. The field coil resistance should also be checked - also ensure the rotor is correct, it was not unknown for POs with a lathe to "lighten" the rotor/flywheel by removing metal: too much removed and the power output drops off precipitously.
The #1 cause for bad charging is simple overloading with high power headlights, driving lights, heated grips, ignition systems, etc... #2 is corrosion on the harness connectors, fuse contacts, and switch contacts. A thorough check, clean, and tighten of all these is required every 5-10 years or so - and that was probably never done. Bullets where the clear plastic sleeve has turned black from heat may be permanently damaged because the metal has lost its temper from overheating. Any with charred sleeve, insulation, or conductor must be replaced or bypassed (with soldering or (less excellent) a compression splice).
Offline strynboen
« Reply #8 on: April 01, 2015, 08:52:06 AM »
meldet fuseboxes...schrev it off the bike..and take rear side off..it meltsoften from backside
