Author Topic: 1969 honda 350  (Read 965 times)
Offline anthonyogden
1969 honda 350
« on: March 31, 2015, 06:29:33 AM »
I have  been working on a 1969 Honda 350  one cylinder in not firing and has fuel shooting out of the exhaust   thought it might be a stuck valve but everything seems to move smoothly  the bike will start just fine and idle all day   but if u manually throttle up one side it just bogs down as for the other it revs right up   any tips would be greatly appreciated
Offline Vinhead1957
Re: 1969 honda 350
« Reply #1 on: April 21, 2015, 06:26:55 AM »
Measure your spark plug cap.  If good, snip 1/4 inch off and re install.  It helps to roll back the rubber cover up the wire.
Offline links56
Re: 1969 honda 350
« Reply #2 on: April 21, 2015, 06:46:16 AM »
How long have you had it? Has it ever ran right or is this a new issue? See if Vinhead's advice helps you, let us know. If it was a stuck valve you would know it. The plug is either not getting good spark with a load on it or it is getting too much fuel and fowling the plug out. Which cylinder is it? and what do the plugs look like?
