Author Topic: suzuki t500 titan  (Read 6138 times)
Offline bear
  • Leeton in Australia
Re: suzuki t500 titan
« Reply #25 on: September 03, 2018, 08:41:10 PM »
Number 91 could be a Kawasaki Triple?
Correct.
Offline jaytee-nz
« Reply #26 on: September 03, 2018, 09:26:50 PM »
Bear - is number 90 a TZ700/750 engine ?
Offline bear
« Reply #27 on: September 03, 2018, 09:44:12 PM »
Yes it is. Well spotted. ;)
The motor has a very interesting history.
When I have a little more time I will post the story behind it.
Brian
So......one to go :)
Offline jaytee-nz
« Reply #28 on: September 03, 2018, 10:12:51 PM »
93 is a XS or TX (depending on the year) Yamaha 650 I think.
Offline Zunspec
« Reply #29 on: September 04, 2018, 10:13:47 AM »
Got this sweet machine for $150......with title!
After removing handsfull of rust from the right cyl, it took a month soaking and twisting on a puller to break it free. Going to try and re-use the pistons with new rings and a hone job.
The PO was in the process of a re-furb?????
Note the rear sprocket on the wrong side!!!!
Hello Brewsky,  A very good deal at $150  8).  If you are looking at restoring it to std. the hard parts to find will be the F & R mudguards and Seats.  Mitaka make very acceptable pistons for road use although you can still source them from Suzuki at a fruity price (GT750 pistons fit too).  They make good cafe' racers, here's a photo of one being converted for racing, all it would need is a set of lights for the road.
Offline bear
« Reply #30 on: September 04, 2018, 06:03:31 PM »
Right again.
That motor was stroked and bored to a little over 1000cc.
Brian
« Reply #31 on: September 04, 2018, 09:30:27 PM »
We used to race a Titan based sidecar back in the early eighties. (When I had hair)
Won an Aus Dirt Track Title in 1982 I think?
The motor had some very rare TR components.
Can you pick the motors used in the other sidecars?
It's quite a distinguished collection for vintage mc buffs. :)
Brian
So which ugly mug belongs to you, Brian? ???
Offline scunny
  • don't call me expert
« Reply #32 on: September 04, 2018, 11:58:25 PM »
They are all very handsome gentlemen, as scottly put it bluntly. which mullet are you wearing Brian ?
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline brewsky
« Reply #33 on: September 05, 2018, 01:20:29 AM »
Thanks for the info.
This one has been on the back burner for a while, but I'm beginning to get the itch.
I think I have most everything, although some parts are pretty rough shape.
My intent was a budget rescue rather than full blown restore, but it's the crank I'm most worried about, as the bottom end had some water in it also.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
ken65
« Reply #34 on: September 05, 2018, 02:00:34 AM »
heres one a friend did a year or so ago.
Offline brewsky
« Reply #35 on: September 05, 2018, 03:40:05 AM »
Nice!
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline Zunspec
« Reply #36 on: September 05, 2018, 03:51:16 AM »
Hello brewsky,
You can get Rod/big end + shims/crank pin kits from a few sources for around £90 GBP (you'll need 2).  Similarly with main bearings.  I woud use genuine Suzuki crank seals as they are still listed by Suzuki.  One US based crank builder, Bill Bune, has a pretty good reputation for his work.  Pistons are available from Suzuki, Mitaka (cast) or go up market and fit Weisco or Wossner (forged).  A full engine re-build for a T500 can get costly, but I guess that's not unusual for any engine.  The crank in Gary's bike cost him £800 GBP (pork chopped, lightened, all new bearings/rods etc.  Luckily the Suzuki main bearings are very robust so if the have not suffered rust will only need a swap out of crank seals.
Cheers  Geoff
Offline bear
« Reply #37 on: September 05, 2018, 06:48:13 AM »
Brian
Oy.....that's enough from you two.
If you must know, I'm the ruggedly handsom bloke with the coke can in his hand.
You might be right about the mullet though ::)
Offline bear
« Reply #38 on: September 05, 2018, 06:52:12 AM »
Hello brewsky,
Cheers  Geoff
New crank seals are an absolute must if these motors have been sitting for any length of time.
Brian
« Reply #39 on: September 05, 2018, 07:50:55 AM »
Gorgeous!
