Author Topic: my cb750k rebuild  (Read 1805 times)
Offline jules
my cb750k rebuild
« on: April 05, 2015, 04:01:10 am »
Hi everyone, I've inherited my late fathers 750/4. it's a 77 chassis with 75 motor, tank and if i remember correctly from when i was younger it has a k2 front end. Dad dismantled the bike about 18 months ago to do the timing chain and restore it to some extent when he died suddenly late last year. I've been slowly piecing it together from the shed full of spares.
I've run into a wall with the front brakes recently, I've got two types of brake calipers but both hit the rotor. Has anyone got any clues as to what could be the issue?
« Last Edit: April 05, 2015, 04:11:11 am by jules »
Re: my cb750k rebuild
« Reply #1 on: April 05, 2015, 08:19:16 am »
Welcome to the site, nice looking bike. Sorry to hear about your father, lost mine a couple years back too.
The early K models used a different caliper mount, the lower forks are different too. Is it possible you have the early fork lower with the later caliper mount?
Offline jules
« Reply #2 on: April 05, 2015, 04:40:59 pm »
I've got two different caliper mounting arms as well as the large and small calipers but haven't found a winning combination as of yet. I've been told there were two sizes of rotors?
« Reply #3 on: April 05, 2015, 05:14:13 pm »
Hi Jules and welcome. You say its a 77 frame with a 74 motor, just check the chain line, the 77's had a 10 mm wider chain line, the 77 engine had a wider chain line because the counter shaft was 10mm wider than the earlier 69/76 750's, so the sprocket carrier was also 10mm wider, if it still has all the 77 rear wheel and spacers and sprocket carrier and swingarm then the chain will be out of alignment 10mm, this can be corrected by using an earlier rear sprocket carrier and adjusting the rear spacers on the left hand side.... Just something worth checking... ;)
Offline jules
« Reply #4 on: April 05, 2015, 06:56:30 pm »
Thanks for the helpful info guys, I've checked the sprockets and they line up spot on.
I've measured up the 3 rotors I've got here and they're all 296mm, so I think I may need to find myself a 290mm rotor to fix the front brake issue.
« Reply #5 on: April 06, 2015, 05:02:43 am »
Welcome, Jules.
For brake parts you can post in the Wanted section or PM Bill Benton:
http://forums.sohc4.net/index.php?action=profile;u=11731
and ask him, chances are he will have what you need.
Edit:  my bad, didn't know you are Aussie :)
Offline jules
« Reply #6 on: April 07, 2015, 03:47:07 am »
Well I've had success with the brake situation, I found a 280mm rotor and it all fits spot on. My question is though, what cb750 ran a single 280mm rotor?
Excuse the caliper bolts, they're just there to hold it all in place.
Offline jules
« Reply #7 on: April 07, 2015, 04:27:10 am »
Sadly this disc is too small... The pad hangs off the edge of the disc so it looks like ill just get one of the 296mm rotor's taken down to 290mm
« Reply #8 on: April 07, 2015, 04:46:44 am »
You shouldn't have to do anything to the rotors, what model front end is that..?
Offline jules
« Reply #9 on: April 07, 2015, 05:35:33 am »
As mentioned above it's a k7 with a k2 front end but for some reason I've only got 296mm rotors which are too big to let either of the brake calipers  mount up properly.
The only other rotor I have here is a 280mm which is too small.
« Last Edit: April 07, 2015, 04:20:25 pm by Retro Rocket »
Offline jules
« Reply #11 on: April 07, 2015, 06:53:42 pm »
I've got both calipers and mounting arms but only have the bigger rotor.
« Reply #12 on: April 07, 2015, 08:15:09 pm »
I have a 750 rotor sitting right next to me and its 296mm, thats the correct diameter for a K2 disc...?  You must have mismatched parts or something, something isn't adding up...?  Sorry I can't do any measurements, I have non stock front ends for my bikes, I don't have a complete 750 front end but I have a disc, actually 2 discs, and they are both 296mm...
« Reply #13 on: April 07, 2015, 08:46:27 pm »
Mick's right, something just doesn't add up.  Do you have two differant caliper arms? Is it possible you have parts from a non-750?
Offline jules
« Reply #14 on: April 09, 2015, 08:47:11 pm »
After much stuffing around I've found the 280mm rotor is from a 75 gl1000, this leads me to think somehow the k7 we pulled the spare front end off had a gl1000 front end aswell as the brake mounting points on the forks are in an identical spot. I'll be on the lookout for another 280mm rotor so it has a twin disc front.
« Reply #15 on: April 09, 2015, 08:51:36 pm »
There ya go.  Installation of the GL front end is fairly common on these bikes, good way to get the twin front disc setup.
« Reply #16 on: April 09, 2015, 10:03:36 pm »
Check out the build thread for my Nine Lives CB750K7. I swapped a 1976 GL 1000 directly on. It's a direct fit - better forks and brakes.
Offline jules
« Reply #17 on: April 09, 2015, 10:18:48 pm »
Direct fit sounds amazing haha. Will definitely be keeping an eye out for one that's being wrecked here in Australia.
