Author Topic: Cylinder Gasket Removal 1971 CB500  (Read 1777 times)
Offline cb
« on: April 06, 2015, 04:13:33 PM »
I'm trying to remove my cylinder gasket.  I have tried spray-on gasket remover and heat, and nothing works.  After trying a brass brush on a Dremel, it appears that the middle of the gasket is brass.  It looks like brass, it takes a nice polish, and it seems to be metal.  This gasket is really stuck on.  Does anyone have any suggestions for its removal, please?
Offline cb
Re: Cylinder Gasket Removal 1971 CB500
« Reply #1 on: April 06, 2015, 06:03:12 PM »
Thank you for the advice and the encouragement.  I am honing the cylinders, replacing the rings, and lapping the valves.  At least that's the plan.
Offline sammermpc
« Reply #2 on: April 06, 2015, 07:43:22 PM »
Just did the same. I had really great luck with a dremel tool and some scotchbrite wheels. You can get em' cheap on Ebay — packs of 30 — or just make your own with a little screw-on mandrel and scotchbrite squares. I also found that synthetic steel wool worked really well.
After I did all that cleaning up, I took em' into a shop for honing, etc., and they got everything way, way cleaner for $20.
1972 CB500, 1979 CB750F SS (dohc), 1982 Yamaha Maxim XS400
Offline MickB
« Reply #3 on: April 07, 2015, 02:46:10 AM »
I had the same problem and used a cheap ($20 from Aldi) Die Grinder with a nylon  surfacing disc. It'll take off the gasket quickly without damaging the surface.
It worked great for me.
Offline przjohn
« Reply #4 on: April 07, 2015, 06:16:17 PM »
Are you doing the work, or having a shop? If a shop, have them deal with the gasket when they hone the bores.
+2 on this method. I use to do all the cleaning and glass beading the fins until they told me they would do it when boring and honing for not much more.
Offline cb
« Reply #5 on: April 08, 2015, 03:40:56 PM »
Thank you all for the good ideas.  I'm not planning on taking it to the shop, so I'll try the die grinder and the dremel methods.
