Author Topic: Cb750 cylinders 1 and 3 aren't firing?  (Read 1835 times)
Offline Jaxbchcb
« on: April 07, 2015, 07:41:39 AM »
My cb750 sohc cylinders 1 & 3 aren't firing for some reason but when I switch the coils the problem moves with the coils!? I know the coils are good because I chec with multimeter, the points are good and timing is perfect, and the spark plugs are new so I have no idea what's go on! Any help please?
Re: Cb750 cylinders 1 and 3 aren't firing?
« Reply #1 on: April 07, 2015, 07:43:41 AM »
Odd.  The cylinders are paired 1-4 and 2-3.
You say the problem moves with coils, how does it move?
Offline goldarrow
  • one day, i'll be an
« Reply #2 on: April 07, 2015, 07:46:34 AM »
Stock coils rarely go bad.  Check make sure wires are good, also one coil goes to 1 and 4, the other coil goes to 2 and 3.   Condensers often need replace.
CB550 K0
Offline Jaxbchcb
« Reply #3 on: April 07, 2015, 08:39:26 AM »
If I put #2 coil on #3 it works etc.
Offline Jaxbchcb
« Reply #4 on: April 07, 2015, 08:41:25 AM »
Yeah it's weird I checked the coils and those are good. How would I test the wires with a multimeter?
« Reply #5 on: April 07, 2015, 08:42:16 AM »
Sorry, can't see the inside of your head from here.
coil 1 connected to 1-4
coil 2 connected to 2-3
Which one is not firing?
Now you move the coil 1 to feed cylinders 2-3 and coil 2 to feed 1-4.
which one is not firing now?
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #6 on: April 07, 2015, 08:44:29 AM »
1/3 are not a pair. The leads from one coil should be going to 1/4 and the leads from the other coil going to 2/3 (so make sure that is there first!).
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Jaxbchcb
« Reply #7 on: April 07, 2015, 11:06:31 AM »
Thanks for the replys! I found a wiring diagram and found out what yall were talking about that 1 and 4 are on one coil and 2 and 3 are on another. I guess the guy who had the bike before me put the coil wires on 1234 haha so no wonder it was acting all crazy!! But I corrected it and everything is good now
