Author Topic: valves are hitting...  (Read 2241 times)
Offline oldhatt45
  • The person called in at the last minute to share the blame is the...
  • Just an Old Guy that's gone to the Dogs
Re: valves are hitting...
« Reply #1 on: April 07, 2015, 02:53:44 PM »
perrito,
The third picture looks like the cylinder has cracked.
In another picture the head around the combustion chamber looks like it has been ground out past the point where it mates to the cylinder.
If these two things are true, I would personally question using either the head or the cylinders.
Charlie
Offline perrito
« Reply #2 on: April 07, 2015, 03:13:17 PM »
That's the head gasket that makes it look cracked- it's def blown. Any info out there for what changes were made on different year heads?
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #3 on: April 08, 2015, 07:55:36 AM »
Hey guys long time listener first time caller. How bad do these pics look? My buddies 76' motor locked up so I tore the top end down, this is what it looks like. Pistons ok to use? It looks like the underside of the head had a grinder taken to it just outside the valves??? I'm thinking new valves but any ideas how the valves would have hit the piston? Thanks.
Made it easier :D
--Evan
1975 CB750K "Rhonda"
« Reply #4 on: April 08, 2015, 07:58:57 AM »
The surface of the head looks awful. Can it be fixed by decking it?
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: April 08, 2015, 08:31:53 AM »
Tell us more about the motor locking up.
Valves hitting the pistons would have to mean a pretty serious issue in a stock motor.  You'd have to have a severely worn cam chain and tensioner, or have it jump a tooth (which I've never heard of happening) or something similar.
mystic_1
- John Augustus Shedd
Offline Vinhead1957
« Reply #6 on: April 08, 2015, 01:27:28 PM »
Valve job at least,  the valves need to be checked for straightness.  What caused it? Timing!  The chain was either too sloppy and jumped a tooth or set up improperly.
Offline perrito
« Reply #7 on: April 08, 2015, 02:44:26 PM »
Thanks for the replies guys- here's what it is: My buddy bought the bike not running about a year ago, the seller said it ran great but needed carb work (don't they all...) I had a look and tweaked the carbs and it fired up and sounded great- he rode it away but a few hours later he said it was stalling while taking off ( letting out the clutch) we brought it back and I pulled the clutch- wasn't too bad it had a couple broken fiber plates but I replaced and put it back together- same issue. I was rolling it over with a socket wrench to line up the timing mark and it locked up, so not when it was running. I pulled the head and that's what you see. The surface area around the valves looks terrible, i'm just looking for ideas on what to do next. I figured new valves seals etc, it's not much to do pistons from here on. anyone have a decent head for sale??? Thanks for fixing the pics- some sites only like to use the links.
Offline mystic_1
  • 1970 CB750K
« Reply #9 on: April 08, 2015, 07:06:34 PM »
What is the state of the cam chain and tensioner assembly?  You need to find the root cause of the interference problem.  The rubber rollers on the tensioner, especially the big one, tend to go bad in a pretty serious way.  Also check for badly worn cam sprocket teeth.
Also, is the cam stock?  It's pretty quick to measure base circle and lobe height, your manual will have the stock specs.
I'd guess this motor was overheating maybe, from the state of the head gasket?  I believe repeated extreme heat cycles can make them go out-of-round line that.
I think there's a good chance that the grinder marks you're seeing are from the factory.  Line workers apparently did hand cleanup work on the castings and they didnt always do a great job.
mystic_1
Offline perrito
« Reply #10 on: April 08, 2015, 07:27:25 PM »
I haven't pulled the jugs yet but I'm thinking that new pistons is the way to go, i'll check he cam chain tensioner then. I don't know about the cam yet, haven't measured it. I know nothing about this bike- it's a chop but it looks like the guy that built it did a decent job. Interesting comment about the grinding marks. Any idea of the year of the head? the only marks I can find are an X3 and whatever is in this pic:
http://i1305.photobucket.com/albums/s550/mamato23/Screenshot_2015-04-08-10-39-42_zpsdyrljiie.png
Offline mystic_1
  • 1970 CB750K
« Reply #11 on: April 08, 2015, 07:34:10 PM »
New pistons do seem like the way to go.
No way to be 100% sure of the exact year of your head but the sealing rubbers between the cylinders and head, plus the domed pistons, suggest an F model engine or a 77/78 model engine I believe.  Barring other evidence there's no reason to believe so far that the head doesn't match whatever the engine number indicates.
I assume this is the chopper in question?  Is that an Santee frame?  I see one of the Santee electrical system boxes tucked in under the carbs there.
mystic_1
Offline perrito
« Reply #12 on: April 09, 2015, 06:30:56 AM »
Thanks Mystic, that's not the bike in question, although I did go through a lot of the same issues, that was my first build. The frame isn't santee and I had a lot of opinions about where it came from- the closest I could tell was GME-probably a custom job. Before I got it someone dropped a battery bolt in the tank and it made it's way through the motor and lodged between the head and one of the valves. The motor #'s on the one i'm looking at show it to be a 76'.
Offline Old Scrambler
« Reply #13 on: April 09, 2015, 02:43:59 PM »
Bolt got from tank to head..................must have been a huge petcock and garden hose feeding a Holly ??? ??? ???
Those swirl marks on the head look like its already been shaved..........and poorly :(............its cut into the valve seat material.
Compare it to a stock K or F0-1 head and proceed. Tell us about the cam profile.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline perrito
« Reply #14 on: April 09, 2015, 04:02:07 PM »
EDIT:I think it was dropped into the oil tank not the gas tank.... I rode it for a couple years before it finally locked up on me.
