Author Topic: Cb400four, broken exhaust stud  (Read 1963 times)
Offline radarlove
« on: April 08, 2015, 07:30:33 PM »
I just picked up a '75 cb400four, with 6,000 miles. The bike is really clean, but someone knocked it over before i took it home, dented the pipe and broke an exhaust stud. My might was too novice to get a Heli Coil to work right. A knuckle head tried drilling the hole out with an easy out, and now i believe i need to weld the hole up and re tap it.
Offline radarlove
Re: Cb400four, broken exhaust stud
« Reply #1 on: April 08, 2015, 07:32:50 PM »
More pics!
« Reply #2 on: April 08, 2015, 07:33:57 PM »
Aren't the split clamps on backwards?
Offline radarlove
« Reply #3 on: April 08, 2015, 08:46:19 PM »
Probably, thanks!
Offline MoMo
  • Ride like you're invisible
« Reply #4 on: April 09, 2015, 02:55:13 AM »
split collars are on correct
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #5 on: April 09, 2015, 08:10:10 AM »
See if you can get the helicoil out cleanly, and measure the hole. It's a longshot but you might have enough meat to tap for a TimeSert. I tried and failed to see what the diameter of the drill is in the 6mm kit, but with a bit of digging perhaps you can find out.
https://www.belmetric.com/timesert-metric-kits-inserts-m6x10-c-217_218_228.html
I have a motorcycle problem.
Offline iron_worker
« Reply #6 on: April 10, 2015, 10:18:35 AM »
Offline NobleHops
« Reply #7 on: April 10, 2015, 11:11:02 AM »
Offline radarlove
« Reply #8 on: April 15, 2015, 01:54:53 PM »
i rebuilt the carbs and got it running well with a temporary fix of tie wire holding exhaust on, just so I can identify as many issues before tearing it down. It's a shame it was damaged, but at least I have another basket case that's might come in handy.
