Author Topic: Removing control switch screws  (Read 752 times)
Offline eigenvector
« on: April 11, 2015, 03:26:29 PM »
I have a short circuit in the control switch, most likely the headlight switch.
So removing the screws I notice that the interior screws are outright impossible to move.  The screws holding on the plates that secure the wiring are without a doubt the softest of metal and secured on like they hold the universe together.
To prevent stripping them out - does anyone here recommend a technique for removing them.  I've tried liquid wrench, that did nothing.  I'm loathe to try heat in the event I melt the wiring making my problem worse than it already is.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Re: Removing control switch screws
« Reply #1 on: April 12, 2015, 09:29:02 AM »
 Put your best fitting screwdriver in the screw and whack it with a hammer.  Be sure it's resting on something soft and secure.
Offline Airborne 82nd
« Reply #2 on: April 12, 2015, 09:56:14 AM »
That is the important part. If you try heat use only a hair dryer.
Offline eigenvector
« Reply #3 on: April 12, 2015, 10:29:00 AM »
Well I didn't have to whack it with a hammer, but after a day and a half soaking in WD-40 and using my best screwdriver, I managed to get the interior plates loose.
Prognosis - there was a colony of (dead) flies tucked in there and the solder joint for the high beam is just BARELY out of contact with the power joint.  I'll have to file down the solder some more to prevent arcing and what I assume was the cause of my short.  Plus I'll need to dry it out and clean the assembly - it's soaked with oil and rain.
Rob
1977 CB550K
1983 VF750S Sabre
