Author Topic: wiring help needed  (Read 1070 times)
Offline scotto
wiring help needed
« on: April 12, 2015, 04:35:21 AM »
Hi guys,I recently purchased a replacement blinker switch from Z1 parts for a 1975 CB 750,all wires matched up wire for wire but 2,I am left with a black with red tracer & a black with a brown tracer. The old switch doesn't have these colors or are they in the schematic that I can see from the original owners manual,can anyone help me,thanks Scott
DH
Re: wiring help needed
« Reply #1 on: April 12, 2015, 08:58:18 AM »
How many wires does the old switch have?
« Reply #2 on: April 12, 2015, 11:01:00 AM »
New made switched have not exactly the same color codes, but similar.
Both cables brown/black and brown/red are visible in the cicruit diagram.
Clutch switch, make it possible to start with electrical starter despite no neutral, the other 12V feed from fuse box.
I marked all wires with tape and text before I connected anything. Honda circuit diagram has all details. My European sold bike (K6-76) has the old blinkers and rear lamp as the early ones had in USA. No position lamp in blinkers that you might have according to the diagrams.
« Last Edit: April 12, 2015, 01:25:09 PM by PeWe »
Offline Airborne 82nd
« Reply #3 on: April 12, 2015, 11:18:06 AM »
Clutch switch (making it possible to start with electrical started desoite no neutral, the other 12V feed from fuse box.
PeWe OK you lost me on that one. ??? I tried looking it up but can not find it.
« Reply #4 on: April 12, 2015, 01:24:05 PM »
I blame my keyboard... or Microsoft bug  ;D My fingers do not always hit were aimed.
If  a gear is in (not in neutral ) the electrical starter will not work. Ok if clutch is used and switch is working.
Photos found in this forum
« Last Edit: April 12, 2015, 01:31:47 PM by PeWe »
DH
« Reply #5 on: April 12, 2015, 01:47:16 PM »
As part of the turn signal switch?
« Reply #6 on: April 12, 2015, 01:58:41 PM »
see the circuit diagrams where the cable from clutch switch is going and the color it has, Honda diagram
