Author Topic: Gasket Kit Help..What is everything?  (Read 2188 times)
Offline Cleric40
« on: April 14, 2015, 10:27:33 AM »
Hi All,
I am working on my engine rebuild and my kit contains all of gaskets/o rings needed. Problem I am running into, they aren’t identified! I have a general idea of what some are but some I don’t know, mainly the o-rings
Can anyone help identify/confirm my predictions below?
12329-323-000 - Breather Cover Gasket - x1
12391-323-000 - Cylinder Head Cover Gasket - x1
91302-001-020 - O-Ring 30.8mm - x12— 4x for Intake manifolds, 8x for Tappet covers
91303-035-000 - O-Ring 11 x 2.5mm - x3—Valve oil control at engine base, but why 3?
91319-323-000 - O-Ring 6 x 3mm - x4--?
91301-200-000 - O-Ring 10 x 1.6mm - x8—Valve guides (wont use)
91301-323-000 - O-Ring 5 x 2.4mm - x2 – Valve oil control between jugs and head
91304-286-000 - O-Ring 61.8 x 2mm - x4 – Engine jugs/sleeves
12251-374-005 - Cylinder Head Gasket - x1
12191-374-000 - Cylinder Base Gasket - x1
18291-390-000 - Exhaust Pipe Gasket - x4
12209-333-005 - Valve Stem Seal - x8
91305-323-000 - O-Ring 5.8 x 1.9mm - x1 --?
11398-323-000 - Oil Pump Gasket - x1
30372-300-300 - Points Cover Gasket - x1
11394-390-306 - Crankcase Cover Gasket - x1
11691-323-000 - Alternator Cover Gasket - x1
31282-323-300 - Starter Motor Cover Gasket - x1
Any help is greatly appreciated, thanks in advance.
Cleric
Offline MickB
Re: Gasket Kit Help..What is everything?
« Reply #1 on: April 14, 2015, 10:54:15 AM »
I had the same problem, suggest you measure the O rings to ensure you have the correct O ring for the right part.
Offline Cleric40
« Reply #2 on: April 14, 2015, 12:36:56 PM »
Thanks, I intend to measure them to identify them. However, I still need help identifying where they go once measured....
Offline Phinn
  • Subversive
« Reply #3 on: July 29, 2015, 11:47:07 AM »
I know this is an old topic, but I was just trying to figure out the answer to this problem.
There are three (3) 11x2.5 o-rings (91303-035-000) on the crankcase, because two of them go around the two center-rear cylinder studs.
The third one is the seal for the oil path plug cap on the left side of the crankcase, near the base of the #1 cylinder.
Incidentally, there are two more o-rings just like them, on the same two cylinder studs, but they go on top of the cylinder block.
(For some reason, my "complete" gasket set only had two, when I needed at least four, maybe five if I were replacing all of them.  To make it even more confusing, Honda used four different part numbers for this o-ring.)
1978 CB750K -- "Mouse," a former basket case, resurrected
