Author Topic: Adjusting cam tensioner with engine on? (Rattle noise)  (Read 1382 times)
Offline neurotoxin312
« on: April 15, 2015, 06:10:16 PM »
So I've been having this rattling noise that I hear all the way up through about 6500 rpms. Sounds like it is the cam tensioner and when I took it to the mechanic he wasn't sure upon first sight/hear.
(1) I've tried adjusting it several time (correctly) and it didn't solve the problem.
(2) I thought that it could have been engine knocking and tried to also get gas with a higher octane with no avail.
(3) Spark plugs seem fine.
I haven't synced the carb as yet but I plan to do that along with valve adjustments and oil change this weekend. I also got a new rubber gas tank mount just in case it could be metal rubbing on metal there.
What I am asking is how safe is it to run the engine very low, while adjusting the cam chain tensioner VERY VERY gently to see is this makes the rattling noise go away? At least I would know that I could disregard other engine components this way.
Offline Tews19
  • I am no
Re: Adjusting cam tensioner with engine on? (Rattle noise)
« Reply #1 on: April 15, 2015, 06:15:34 PM »
What bike are we talking about? 550? If so yes you can adjust while the bike is running
1970 Honda CB750 survivor.
« Reply #2 on: April 16, 2015, 07:40:17 PM »
Yes I forgot to mention that it's a cb550. Really? You could adjust it with the bike running & and it is not risky in an way?
Offline mrbreeze
  • Not your average
« Reply #3 on: April 16, 2015, 07:44:30 PM »
I'd bet on the noise going away with a carb synch.
MEMBER # 257
Offline CycleRanger
  • No comment about being an
« Reply #4 on: April 16, 2015, 08:26:15 PM »
Yep.
« Reply #5 on: April 17, 2015, 03:32:50 AM »
My CB750 user manual say that the tensioner should be adjusted during idle which is completely wrong.
It just become worse.
I guess that the design is different than CB550. I use the kicker and turn engine step by step with a pin inserted in the hole of the tensioner. I'll feel when it is in the inner position and lock the tensioner screw and nut there
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #6 on: April 17, 2015, 09:14:02 AM »
Use an angled flat blade screw driver and 10mm open end wrench. Turn the tensioner screw counterclock-wise to tighten the chain. But don't force anything just enough force to hold it while tightening the set nut. very small hands helps!  :D Do this first as it's part of the 3000 mile tune up. If that doesn't take the rattle out then do a vac sync since that would be the last thing you would do.
« Last Edit: April 17, 2015, 09:15:38 AM by Duanob »
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
« Reply #7 on: April 19, 2015, 09:05:24 AM »
Just adjusted my cam chain tensioner yesterday while engine was running and this didn't seem to help the rattling noise, so I guess I could rule out the cam chain tensioner as the source of the rattling noise. Will be doing a carb sync later this week.
Here is a youtube video of the noise.
« Last Edit: April 19, 2015, 09:21:15 AM by neurotoxin312 »
Offline mrbreeze
  • Not your average
« Reply #8 on: April 19, 2015, 11:57:59 AM »
You will be amazed at the difference!!
MEMBER # 257
« Reply #9 on: April 19, 2015, 12:08:50 PM »
Are you still saying this noise is probably do to the unsynced carbs? Last time I checked (but didn't sync) only carb #2 was off xD
Offline mrbreeze
  • Not your average
« Reply #10 on: April 19, 2015, 12:28:31 PM »
If everything else in the tune up is good....yes.
MEMBER # 257
