Author Topic: Cam Confusion and Problems  (Read 1387 times)
Offline Lammers000
« on: April 16, 2015, 12:19:23 PM »
Hey guys,
So I bought my bike knowing that it had an oil circulation problem. Upon tearing it down completely (split case and all), I found that an oil gallery in the head at cylinder 4 was clogged, inhibiting oil circulation to cylinder 4's cam bearing. As a result, the damn thing eat itself to pieces, removing material from the cam itself. The cam tower was destroyed as well. However it doesnt seem that any metal flakes or chips did any damage else where in the head / valve cover cavity.
My concern is the heat created by the friction. Should I be worried about a cracked head and do you guys suggest I get the damn thing XRayed? Im a college student and money sure as hell wont grow on trees.
My other concern is wear matching. I know cams wear into their respective cam towers and caps. I will be buying a new cam and replacing the cam tower. Should I be concerned about the new cam wearing into a new, but used cam tower? And what about the tower I plan to keep that doesnt seem damaged.
Thanks everyone
Be an Engineer they said. It will be fun they said.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=eb5dqu6vlo9osrbh1evruk72n1&/topic,60973.0.html
Re: Cam Confusion and Problems
« Reply #1 on: April 16, 2015, 12:35:39 PM »
no problem,,, just bay used parts and build them in...its a old engine..all parts have some sluck..but a visual thek can be fine if you áre used to look on this type of engine parts,if not messuring all parts is a must...
and find aut vhy it have lost oilpresure...have there be used silicone fl gasket..vho blockes the restriktion valve to the head..or other failure..pump must be good if the other half engine are fine
i hate all this v-w.... vords
Offline Lammers000
« Reply #2 on: April 16, 2015, 12:37:18 PM »
Yes, it was gasket sealant that clogged the oil gallery.
Offline strynboen
« Reply #3 on: April 16, 2015, 12:48:33 PM »
take the oil sump off. and filter and oil tank.and vash the engine/oill tank in fuel/gas..and blow pressured air through...so all small metal parts are vashed aut. take the oil pump aut too and vask and blow all oil lines through.then buildthe engine back up Again..is it a 750 the engine must aut..is it a 550 it can be in frame..personly, i just have baued used parts..and taken the chance the head are ok..and put it together and test ride it..thats just mine idea..let somone other give some ideas..
« Reply #4 on: April 16, 2015, 03:09:55 PM »
I have had this exact problem happen but the oil blockage was caused by longterm storage rather than silicon.  The best thing to do is replace the whole valvetrain as a set, cam, towers and rockers, and shafts, all from the same engine.  This is what I did and most everything has been well for 9000 miles or so.  Good, used but mismatched parts can be used, it is just not as ideal.  The parts will have to re-establish a wear pattern and this will reduce the ultimate longevity of the parts but probably not to an unacceptable level.
    In my situation, cam and tower destruction was rapid and catastrophic and only on the #4 end of the engine, similar to yours.  I have no evidence of cylinder head damage as I have not yet torn the motor down beyond the cam towers.  However, my valve cover will no longer hold a seal for more than about 1000 miles, despite 3 new gaskets and attempts at "bodging it shut.  The leaks always begin on the #4 end of the engine.  I  believe the camshaft failure warped the valve cover or the gasket rail.
« Reply #5 on: April 18, 2015, 06:27:49 PM »
The damage that happens with a blocked journal is quick (like, 10 minutes max). It's exceedingly unlikely that the rest of the head got 'hurt' in the process.
Offline b5rider
« Reply #6 on: April 18, 2015, 11:19:04 PM »
If there was blasting media left in the engine after a rebuild and it gouged the cam and head,  would I need to split the cases. The engine was only ran about 25 miles after the rebuild
1984 Honda Elite 150
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
1978 CB550 now 603cc w/sidecar
The key to life is to make sure the line to put flowers on your grave is longer than the one to piss on it.
Offline Lammers000
« Reply #7 on: April 19, 2015, 01:13:31 PM »
If there were blasting media left in the engine period Id suggest a rebuild. Those particles can easily circulate throughout the whole bike and can wear out pieces here and there and cause uneven wear, thus decreasing the life of some parts. They can also do damage to your oil pump and other components in the bottom end so YES I do suggest splitting the case and cleaning everything thoroughly.
Offline b5rider
« Reply #8 on: April 19, 2015, 06:34:39 PM »
Thanks, I figured.
1998 Yamaha 650
2004 Honda 750 ACE
1975 CB550
1978 CB400A
