Author Topic: Yet ANOTHER dyno result  (Read 8389 times)
Offline scondon
  • Mmmm......tasty bugs
« on: October 16, 2006, 05:58:14 PM »
Sorry ya had to wait so long,Sam ;)
Bike: 78 750F
        836 Bore
        ported K8 head
        Megacycle 125/65 cam
        Stock '78 750 carbs (125 mains)
        Stock airbox(drilled, K&N filter)
        Dyna S ignition
        Dyna 3.0 coils
        Kerker 4-1 Exhaust w/ med. competition baffle
        I put this bike on the dyno for the express purpose of getting a chart of how the engine eats fuel and how that, in return, affects performance. What I got will not only help tune the bike I have, but also give #'s to compare with the bike I'm putting together. First dyno run for me, pretty happy with the info it provided :)
« Last Edit: October 16, 2006, 07:34:25 PM by scondon »
Offline heffay
Re: Yet ANOTHER dyno result
« Reply #1 on: October 16, 2006, 06:01:19 PM »
pretty smooth curve... i'd work on the midrange and see what happens
thanks for the post
Offline scondon
« Reply #2 on: October 16, 2006, 06:10:55 PM »
thanks for the post
  I've already dropped the needles since this run and the midrange is better. Still have to work on the idle circuit, but I won't be making any more carb adjustments 'til I get the fuel levels in the bowls straightened out. Here's the related topic (It's a pretty long read :P):
http://www.sohc4.us/forums/index.php?topic=14411.0
« Reply #3 on: October 16, 2006, 06:30:37 PM »
Congratulations Sean. I've been following with interest and it looks like you're taking a methodical approach to dialing in the carburation.
I remember working through all that with my 810 moons ago. It was a production racer so it was wfo most of the time, had hollowed out stock pipes. (everybody cheated) I'll send you a picture of what I did to the stock box besides drilling.
Greg
« Reply #4 on: October 16, 2006, 06:42:02 PM »
looks pretty sweet sean!
where did you bring the bike to get dynoed?
greg
Offline scondon
« Reply #5 on: October 16, 2006, 06:46:11 PM »
Thanks Brent. Yeah, the problem with going from fixing brakes and gapping points to doing a complete rebuild with all that engine work is that I had to learn a lot of stuff all at once. Some areas, like the carbs, got studied initially but not in depth. Float height adjustment, idle adjusting, assembly/disassembly, etc. were all looked at, but really only enough to get the job done. Now I'm coming back to it for further testing/analysis/trial&error/voodoo witchcraft in order to gain a fuller understanding of how the different carb circuits affect each other and, in turn, affect the performance of the bike. My brain hurts :D :D
Offline scondon
« Reply #6 on: October 16, 2006, 06:48:42 PM »
greg
  New shop called Godspeed on San Pablo Ave in Oakland. Pretty nice shop if you ever want to check it out. Employs a lot of the East Bay Rats MC club.
Greg
« Reply #7 on: October 16, 2006, 07:07:15 PM »
yeah, i ride past that shop all the time, and heard it was an east bay rats dive. i'll have to check it out. which shop were they - meticulously organized or hole in the wall?
« Reply #8 on: October 16, 2006, 07:10:45 PM »
Nice one Sean, just two thirds of a gnats dick more than spartys, pretty close you guys. 8) 8) 8) ;)
What number cam dose this motor run Sean ?
When you consider that these are only slightley modded street motors, the figures you have both acheived are quite good.
Remember the stock motor of a K only kicks out about 55/57 at the rear wheel,  if you add about 10 or 12 bhp that you have lost in transmission it takes you a lot closer to Dick Manns factory Daytona Winner.(think it was about 87bhp)  ;D ;D ;D ;)
Well done guys ;)
Sam.
« Last Edit: October 16, 2006, 07:34:24 PM by samcr750 »
Offline kghost
« Reply #9 on: October 16, 2006, 07:11:33 PM »
Did I tell ya my trick for getting the float levels all the same?
Good looking results  :o
Stranger in a strange land
Offline scondon
« Reply #10 on: October 16, 2006, 07:18:11 PM »
   Believe it or not, the Rats run a tight ship=meticulously organized
 ;D Not yet. Hope it doesn't involve glass(see through) float bowls 'cause that's where my thinking's taking me :D
Offline scondon
« Reply #11 on: October 16, 2006, 07:27:11 PM »
Remember the stock motor of a K only kicks out about 55/57 at the rear wheel,  if you add about 10 or 12 bhp that you have lost in transmition it takes you a lot closer to Dick Manns factory Daytona Winner.(think it was about 87bhp)  ;D ;D ;D ;)
Well done guys ;)
Sam.
   Thanks for the reminder,Sam. I forgot to add the Megacycle 125/65 cam to the list(edit).
   I forgot who told me when I was first putting this together that 80 bhp was not an unreasonable # to squeeze out of the components in this engine. I'm pretty sure that I had a better top # when I had the '76 carbs and pods on. If this wasn't my only mode of transportation I would be tempted to to try for more, but that's what the "roller" in the garage is for ;)
Offline kghost
« Reply #12 on: October 16, 2006, 07:33:19 PM »
No glass ;D
I wacked off the stand pipe in an old set of bowls. Added clear platic tubing which I then zip tied up.
Then I set the carbs level and compare the fluid in the plastic tubing.
Ajust floats till they match and are at the proper level.
I think I posted pictures in an old old post of Bob wessner.
I'll see if I still have the pic's on the computer in the shop.
upperlake04
« Reply #13 on: October 16, 2006, 07:36:09 PM »
ahhhh. finally, a sensible, informative, respectful and friendly topic - keep it up boys ;D
« Reply #14 on: October 16, 2006, 07:40:51 PM »
Well done guys ;)
Sam.
Well said Dave ;D
Sean, with the same cam the figure of 80bhp is what we are hopeing for from Chrises motor.  ;)
By the way, when you quoted me you have tried to make out that I spelled transmission wrong ::) ::) ::) ;D ;D ;D ;D ;D ;D ;D
Sam.  ;)
Offline scondon
« Reply #15 on: October 16, 2006, 07:54:08 PM »
No glass ;D
   Nice thing about the '78 carbs is that the fuel drains from the overflow tube, via a passage in the bottom of the float bowl, when you crack the drain screws. No need to whack off the standpipe. The really un-nice thing about these carbs is that the float bowls screw on and are damn near impossible to remove while the carbs are on the bike :(
   I'm going to clean and re-adjust my '76 set just in case I end up putting them back on (the pods that fit them made the highest rpm riding really nice). I've got a nasty set of parts carbs that I just happened to snap a standpipe from one of the bowls(it had a bad weld "fix" from a previous break). Will use your method in setting them up. Thanks :)
Offline Roach Carver
« Reply #16 on: October 16, 2006, 07:56:28 PM »
i just got my results back today. Check it out!
Offline scondon
« Reply #17 on: October 16, 2006, 08:02:48 PM »
  From what I've experienced while fiddling around with this bike I'll be disappointed if you don't make 80 bhp >:( ;D
Sam. ;)
  Sorry, must have been my English to British(er...English?) spell checking program ;D
« Last Edit: October 16, 2006, 08:05:18 PM by scondon »
« Reply #18 on: October 16, 2006, 08:37:56 PM »
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
« Reply #19 on: October 16, 2006, 08:40:31 PM »
 ;D ;D ;D ;D
« Reply #20 on: October 17, 2006, 04:41:08 AM »
Well done guys ;)
Sam.
Well said Dave ;D
Sam.  ;)
First off ...solid performance Sean. Sam, you should get some more if for no other reason your 34mm intake valve.
« Reply #21 on: October 17, 2006, 03:50:12 PM »
Hope so Mike, when you consider we are already on 60 with the stock motor.
The carbs, pipes and ignition should release more than they are doing at the moment, when tied in with the big bore, cam and head work.
Also not forgetting the plugs, the way they have cleaned up the running of the motor is unreal. :o  I would like to see if theres any bhp improvement just from them alone.
Sam.
Offline scondon
« Reply #22 on: October 17, 2006, 04:10:38 PM »
Plugs ??? ???
« Reply #23 on: October 17, 2006, 05:04:48 PM »
Ear plugs, you put them in your ears so you can't hear all the missfires and spluttering ;D ;D ;D
Iridium plugs off Mike, loads cheaper than buying in the UK.
Bike starts easyier, can take of choke sooner, makes the motor respond quicker to the throtel, just the bees knees ::) ::) ::)
Sam.
Offline joeb
« Reply #24 on: October 17, 2006, 05:17:49 PM »
Well Sean its looking good maybe I need to have mine run on the Dyno to see what happens. 8)
