Author Topic: Eastwood 2K aero engine paint?  (Read 959 times)
Offline Speedy
« on: April 19, 2015, 07:36:04 PM »
I've used the regular 2K matte clear on fork legs which turned out great (and stuck on bare polished aluminium) anyone use the high temp clears?  I think the matte might look better than the gloss on my soon to be polished 400F rocker/valve cover, what do you think?
This is a 2 part epoxy paint in a spray can -
http://www.jegs.com/i/Eastwood/352/14931Z/10002/-1?parentProductId=2826057
Offline Whaleman
Re: Eastwood 2K aero engine paint?
« Reply #1 on: April 20, 2015, 03:29:52 PM »
Years ago I used an Eastwood high temp clear. It was not 2 part. It started to turn yellowish after a year. I would be too scared to try again. Dan PS Maybe this new product will not turn yellow.
Offline Muckinfuss
  • "I plan to live forever.....or die trying."
« Reply #2 on: April 21, 2015, 10:54:44 AM »
why not just buy it from Eastwood?  It's cheaper.  Eventually all clear will yellow unless it's a water based poly such as what is used to finish wood.  If you're over 30, you'll be dead before the Eastwood 2k urethane yellows.
1984 Sportster 1000cc XL
1988 Heritage Softail
1974 CB550
1989 Corvette
