Author Topic: 1978 CB750F - Piston Rings  (Read 4695 times)
Wobbly
Re: 1978 CB750F - Piston Rings
« Reply #25 on: April 24, 2015, 05:48:30 AM »
392 is also what the K7 uses.
Offline cgarbe
« Reply #26 on: April 24, 2015, 10:36:14 AM »
Hey guys, my mechanic told me about a place that makes custom piston rings for almost anything as long as you give them the bore size, groove size, etc. They are called Total Seal http://www.totalseal.com, I ust spoke with them and the cost for custom rings is $70-$80 for a pair of cylinders...so $140 to $160 for four cylinders. This is just an option I guess.
On a side note, I've been thinking about installing a big bore (836) however the kit is what $600 plus the price of re-boring the cylinders which costs about $70 per cylinder here in my area. This top-end engine rebuild for me has been quite the strain on my bank account.
New APE Brass Valve Guides: $80
Head Machining for New Valve Guides: $235
New Custom Piston Rings: $160
Labor for Top End Rebuild: $800
I've been trying to rebuild my 1975 CB400F while riding my 1978 CB750F...looks like the 400F project is on hold for a while.
1975 Honda CB400F
1978 Honda CB750F
Offline cgarbe
« Reply #27 on: April 24, 2015, 10:52:20 AM »
KRONUS0100,
you said the 392 piston rings will work on a 1978 CB750F...correct? What is the part number for the rings you installed? I see a few on the cb750supply.com website:
Ring Set OEM Ref. #13011-392-004 (Std.)
Ring Set OEM Ref. #13021-392-004 (0.25mm.)
Ring Set OEM Ref. #13031-392-000 (0.50)
1975 Honda CB400F
1978 Honda CB750F
« Reply #28 on: April 24, 2015, 11:05:14 AM »
KRONUS0100,
Standard Size Piston Ring Set
Japanese made Superior Quality
Fits: Honda CB750K (1977-78)
CB750F (1976) Use for engine serial numbers above #2551568
CB750F (1977)
CB750A (1976-78)
Note: This Set includes piston rings to rebuild four pistons.
Genuine Parts by OEM supplier
Part #: CB-71369
Offline cgarbe
« Reply #29 on: April 24, 2015, 11:07:00 AM »
So I just spoke with my mechanic...the 392 piston rings do NOT fit...they are physically thicker than the ring grooves on the piston. I repeat... DO NOT FIT.
1975 Honda CB400F
1978 Honda CB750F
« Reply #30 on: April 24, 2015, 11:16:25 AM »
IIWY, id get a second opinion from the F guys here, before i totally rule them out.
Wobbly
« Reply #31 on: April 24, 2015, 12:46:06 PM »
He's wrong.
http://www.cmsnl.com/honda-cb750f-750-super-sport-1977-usa_model491/ring-set-piston_13011392004/
Offline KRONUS0100
  • MAD MATT THE MANIAC
« Reply #32 on: April 24, 2015, 03:35:17 PM »
MATT
Offline cgarbe
« Reply #33 on: April 29, 2015, 07:46:32 AM »
UPDATE:
I'm sending my pistons to Total Seal to have them machine the piston grooves to fit Ring Set OEM Ref. #13011-300-024 (Std.) which fits the Honda CB750K-K6 (1969-76). Does anyone have any thoughts on this? I assume this set is going to be easy to find in the future.
« Last Edit: April 29, 2015, 07:55:16 AM by cgarbe »
1975 Honda CB400F
1978 Honda CB750F
« Reply #34 on: April 29, 2015, 08:36:23 AM »
He's wrong.
why the time and expense when the above set will work?
Offline cgarbe
« Reply #35 on: April 29, 2015, 10:11:50 AM »
I will order a set of 392 piston rings from cb750supply.com and see if they fit.
Update:
Actually cb750supply.com doesn't have any in stock...so i'm back to square one...do I wait for cb750supply.com to restock them or do I just sent them to Total Seal and have them machined to fit the #13011-300-024 (Std.) for $12.50 per ring?
Update:
I am mailing my pistons to Total Seal because I'm tired of not being able to find rings...so I'm having them fit to the OEM Ref. #13011-300-024 (Std.) Rings.
« Last Edit: April 29, 2015, 12:33:18 PM by cgarbe »
1975 Honda CB400F
1978 Honda CB750F
Offline Davidov
  • 1978 CB750 F3
    • My CB750F project log
« Reply #36 on: May 04, 2015, 08:34:19 AM »
KRONUS0100,
CB750F (1977)
CB750A (1976-78)
Part #: CB-71369
There's the answer.
-David
