Author Topic: Oil pressure light. Help!  (Read 7801 times)
Offline martin_uk
  • CB750F1 CB750K8
Re: Oil pressure light. Help!
« Reply #25 on: April 25, 2015, 03:51:55 AM »
I followed the wire start to finish and everywhere in between. I appreciate everybody's input, but I really think its the sensor. I'll let you guys know how it pans out when I get it.
1979 CB750 Limited Edition
If the light is on when lead disconnected from sensor, there is a short to earth at some point. Make sure you check for trapped wire and correct colour code in case swapped over at some point.
CB750F1, CB750K8,  Triumph Street Triple R, AJS 350, Triumph 3TA
Offline Staubig
« Reply #26 on: April 25, 2015, 09:29:57 AM »
Okay guys, I figured it out. The Oil pressure and brakes run through a module that controls the stop light. I had replaced my tail with an LED weeks ago, but had forgotten about it since I have had other issues with the bike that just got resolved. The LED drew so little power that the module told the light to turn on because it thought it blew the taillight thanks a ton guys.
Offline mystic_1
  • 1970 CB750K
« Reply #27 on: April 25, 2015, 10:07:50 AM »
Interesting, sort of primeval "check engine light".
Glad you got it sorted!  Gotta love red herrings :)
mystic_1
- John Augustus Shedd
Offline Staubig
« Reply #28 on: April 25, 2015, 11:07:35 AM »
mystic_1
I couldn't see the forest through the woods! Definitely was a learning experience, and I got a kick out of the "check engine light" type feature, so archaic lol
For riders of ALL old bikes: I paid $14 for two 1157 LED bulbs. I just assumed that LED bulbs would be better, they're not. I'm sure there is some sort of adaptation you can make but the LED bulbs were SIGNIFICANTLY dimmer. So don't buy them unless you know what you're doing.
Offline Ozzie
« Reply #29 on: April 11, 2019, 03:08:35 PM »
I’m having the same issue with the same bike.  How did you fix the problem exactly?  Did you remove the led taillight or were you able to install a resistor to fix the problem?
