Author Topic: 750 K2 ports and valves.  (Read 1200 times)
Offline Franken750
  • Adventia b4 Dementia
« on: April 25, 2015, 09:10:59 AM »
Hi Folks.
Well only 4 years late but have finally made a start on my CR style street machine.
My first opportunity to look down the throats of a 750 head and have to say I was a little aghast at the sight.
First up is the valve stem diameter and the port volume it occupies. As it happens I have an R1100S Beemer 4V, that has 34/29mm inlet/exh vaves, but with 5mm valve stems (looked scrawny at first sight but normal now :)).
I'm plan to fit a set of these as my first step towards better gas flow, but not sure about using the full diameter. They will also be lighter than the origionals. Fitted with Ti collets/keepers they should make life easier for the cam and springs. They will also get a TB coating, springs included.
Has anyone ... ... well I just answered my own question. Found this:
http://dynoman.net/engine/valves/5mm_conv.html
Has anyone used this conversion kit, or have knowledge of its use?
Thanks.
1982 Bol D'or CB750
1973 CB750 K3 in bitz in the Franken Lab.
1989 Porsche 928 S4
Re: 750 K2 ports and valves.
« Reply #1 on: April 25, 2015, 10:44:38 AM »
I have installed about 20 of them
« Reply #2 on: April 25, 2015, 10:46:16 AM »
That's the staple of Mike Rieck's Stage 4 head work. A #$%*load of us have splurged. You should see his work! None better.
Who should use this kit?
Anyone who can afford it!
The set-up on this kit is critical and it must be installed by a qualified shop with a higher level of experience than average and the proper tools.
Talk with Mike.
« Last Edit: April 25, 2015, 10:48:29 AM by Jerry Rxman Griffin aka MuthaF'er »
« Reply #3 on: April 25, 2015, 11:52:40 AM »
That's the best advice you'll get on the subject Franken.  ;D
« Reply #4 on: May 05, 2015, 08:23:41 AM »
As Mike says, no disappointments no matter the displacement, as to his Stage III port work. The 5mm kit takes it to the next level and becomes a Stage IV.
