Author Topic: $200 CL buy  (Read 22448 times)
Re: $200 CL buy
« Reply #125 on: May 13, 2015, 07:25:34 AM »
Not sure if you checked,but sparkplug wires, often need ends trimmed or wire replaced.
Also,clean that set of points with a card..sometimes they need recleaning.
« Last Edit: May 13, 2015, 07:38:21 AM by 754 »
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #126 on: May 13, 2015, 10:10:56 AM »
Has electric ignition....
Maybe it was slightly unplugged or something when I was cleaning it. Gonna give it another go today. Also could be the carb that was overflowing.
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #127 on: May 17, 2015, 06:16:48 PM »
2\3 feed from ignition was unplugged :)
Think still runs like ass. Probably gotta get carbs rocked. Is chem dip as good as they say it is?
Gus, Austin, MN.
Offline chewbacca5000
  • I polish covers!
Re: $200 CL buy
« Reply #128 on: May 17, 2015, 06:27:03 PM »
As for carbs get $2 can of valuecraft carb cleaner from autozone.  It goes through varnish like a hot knife through butter.
Spray through all passages and blow out with compressed air.  If the valuecraft is able to pass through all the passageways you are generally good for the cleaning thing.
http://www.autozone.com/fuel-and-engine-cleaners-additives/carburetor-cleaner/valucraft-carburetor-cleaner/523209_0_0/
Floats need to be set to 26mm.
Air screws 1 to 1 1/2 turns out from gently seated.
Make sure tank is spotless by pouring small amount into glass jar.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #129 on: May 17, 2015, 06:49:06 PM »
Cool. Running fresh gas with filter and clear lines. Might still have crud build up in carbs.
Guessing its whacked out carbs...they were so dirty its entirley possible they they may need to be gone througha couple of times.
Its 26 mm from the gasket, correct?
Gus, Austin, MN.
  • I polish covers!
Re: $200 CL buy
« Reply #130 on: May 17, 2015, 06:57:18 PM »
26mm from the black gasket.  Check your fuel by pouring some into mason jar.  If you see anything.  Empty tank and rinse with Kerosene and fill with fresh gas.
Having a clean tank is key.  I would also do that caliper if you have not done already.
Very simple to clean and install new piston without bleeding.
All you do is unhook banjo from MC, fill caliper, install piston.  When you see brake fluid come out up top near MC all air is out of lines.  Reconnect and you should have brake pressure.
Need need for vac or syring.  Do you think that is how Honda did it?  No way.  They could not afford methods that did not work 100% of the time quickly.
5 minutes my way.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #131 on: May 17, 2015, 07:01:18 PM »
I bench synched and did redo the caliper. Also fixed back tire.
If i can get it to run correctly with confidence i will be driving it soon. My boots for airbox are hosed to. Keeping them tight with elec tape to seal for now. Temp fix.
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #132 on: May 17, 2015, 07:03:56 PM »
Beat way to clean slides?
Gus, Austin, MN.
  • I polish covers!
Re: $200 CL buy
« Reply #133 on: May 17, 2015, 07:09:59 PM »
Douse libely with that valuecraft stuff.  I have tried all sprays and this one actually works.  It has the same key ingredient that powdercoater use to strip powdercoat.  Methlychorine.  It will take powdercoat off factory rims.
Wear gloves nasty stuff but works.  I shoot some into my carbs after wintering.
Valuecraft = melt varnish instantly
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #134 on: May 17, 2015, 07:14:16 PM »
Cool thanks! Gotta get a new return spring from hardware store too. Itll come together.
When i was putting it back together the first time, i noticed that the fuel needle jets didnt have washers and one was different from the rest....are either of these relevant? Thanks!
Gus, Austin, MN.
  • I polish covers!
Re: $200 CL buy
« Reply #135 on: May 17, 2015, 07:42:15 PM »
They are fiber washer and you need them.  They seal your float needle seat.
Hardware store spring may or may not work.  If not I am sure I got a spare.
Remember it is your life.  I would not skimp on any safety part, or part that make it run.
You can get a better seal on your air box boots by taking them out of the airbox, dropping them in hotwater and tightening them up, and quickly putting the top half back on.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #136 on: May 17, 2015, 08:02:15 PM »
That's good to know because they overflow alot. Is that fiber washer something i will need from the dealer?
Gus, Austin, MN.
  • I polish covers!
Re: $200 CL buy
« Reply #137 on: May 17, 2015, 08:09:25 PM »
Get 4 of these.  $20 total.  Bye to overflow
http://4into1.com/replica-keihin-2-0-float-needle-valve-assembly-16011-375-004/
Also does your petcock leak?
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #138 on: May 17, 2015, 08:12:21 PM »
Nope.
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #139 on: May 17, 2015, 08:13:09 PM »
Cant just buy the washer?!
Gus, Austin, MN.
  • I polish covers!
Re: $200 CL buy
« Reply #140 on: May 17, 2015, 08:14:44 PM »
Nope.
Did you pour some gas from your petcock into a clear jar?
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #141 on: May 17, 2015, 08:17:13 PM »
Running a clear tube. Tank inside looked clean and i cleared out tank and got new stuff. Running clear lines and gas is nice and clean and filtered
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #142 on: May 17, 2015, 08:24:20 PM »
What size? 2.0?
Gus, Austin, MN.
  • I polish covers!
Re: $200 CL buy
« Reply #143 on: May 17, 2015, 08:29:55 PM »
Yes.  Buying those make it easier to adjust your float height as all the valve springs will be the same strength.
You got a good deal at $200, but you are going to have to spend some bucks or deal with a bike that does not run right.
You can duct tape stuff, but you get poor results.  All depends on what you are happy with.  It is your bike.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #144 on: May 17, 2015, 08:33:35 PM »
After this conversation tonight I ended up ordering the 4 new needle seats and washers and also 4 new carb boots. I kinda like this thing and want tit to run right.
Gus, Austin, MN.
  • I polish covers!
Re: $200 CL buy
« Reply #145 on: May 17, 2015, 08:41:10 PM »
That good cause we want you to be safe too.  In motorcyle safety school they basically told me "cars want to kill you".  So making sure the bike will go and stop when I want it to is very important to me.
Someone is bearing down on you and your not going big problem.  Can make a fast stop another big problem.
Caliper sticks form home, no tools.  Big pain in the rear.  Got call for help.
I would fill a clear jar 1/4 full with gas.  You need that flow to show you if there is stuff in your tank.  The clear tube does not always work.
After shooting that valuecraft nastiness in your carbs immediately blow out with compressed air.  It turns the varnish to solution and will dry again if not blow out.
Wash hands after.  Be safe out there.
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #146 on: May 18, 2015, 07:19:54 PM »
Is the 2.0 the right size. I forgot to specify so they sent 2.0
Gus, Austin, MN.
  • I polish covers!
Re: $200 CL buy
« Reply #147 on: May 18, 2015, 09:35:48 PM »
yes
Offline Sdsbassist
  • Gus, Austin, MN.
Re: $200 CL buy
« Reply #148 on: May 18, 2015, 09:40:55 PM »
Sweet. Gonna pick up some of your death spray wednesday
Gus, Austin, MN.
  • I polish covers!
Re: $200 CL buy
« Reply #149 on: May 18, 2015, 11:04:02 PM »
Good for you.  It is super nasty.  Wear gloves.
